Couldn't find the setting place of the /NOENTRY linker option
Message 1 of 1
      I am making my great efforts try to connect VS2015 C# with 3ds Max for debuging .NET dll plugin these days, but 3ds Max 2018 got crashed on start-up always!
      Autodesk has an official method to resolve this problem as below:
http://help.autodesk.com/view/3DSMAX/2018/ENU/?guid=__developer_3ds_max__net_sdk_troubleshooting__ne...
      3DS MAX HELP/Troubleshooting .NET Plug-ins/3ds Max hangs or crashes on start-up or exit:
      "Temporarily setting the /NOENTRY linker option under: Configuration Properties -> Linker -> Advanced -> No Entry Point will help find any statically allocated instances. ......"
     But I could not find where is the setting place of  the /NOENTRY linker option under Configuration Properties in C# projects. which can be found  in C++ projects only.
     Ask for advice from everybody here!
     Thank you very much!
Replies (0)
