Control noise strength from script
matthew_turnerE7B7E
Observer Observer
matthew_turnerE7B7E
Observer
Observer
So the script below is supposed to create a position list, then a noise controller, this works. However I then need to animate the noise strength.. this is where I have problems and the script no longer works.. any ideas ? Thanks 😊
$.pos.controller = PositionList () -- adds position list
$.pos.controller.setActive 1  -- makes controller active
$.pos.Available.controller = Noise_position () -- adds noise controller
set animate on
sliderTime = 10f
			$.pos.Available.controller.noise_strength = [0,0,0]
-- puts a key frame with custom strength sizes
	set animate off
denisT.MaxDoctor
delete objects
gc()
t = teapot name:#sick_teapot isselected:on
c = t.pos.controller = position_list()
n = c.available.controller = noise_position()
c.setactive 2
s = n.noise_strength.controller = bezier_point3()
animate on
	at time 0f s.value = [0,0,0]
	at time 100f s.value = [0,0,100]
domo.spaji
Don't have to set it active?
Or do you?
denisT.MaxDoctor
You will decide. The #active state does not affect the ability to animate #strength.
By setting the #noise controller to active, we "block" editing of the original translation through the user interface.
matthew_turnerE7B7E
Observer
Observer
Ace! Thank you 🙏
domo.spaji
Ah, OK.
Tnx
