Announcements
Combining two scripts...
Message 1 of 1
So I could really use some help.  I'm trying to import some models into Max with a script custom-made for this file type.  The models are intended for use with .kf (havok) animations.  There are two versions of this script around the web, and each has faults.  The original imports the model really nice and clean, but animations make the character's bone positions 90 degrees around the origin from where they should be, while maintaining original bone rotations.  So the model looks horribly disfigured.
  The edited script seems to work perfectly with animations; they're all upright and beautiful.  Unfortunately it also splits the mesh into many different pieces, when I only need it in one piece.
I've done a few small edits to the scripts but this seems way over my head.  Can anyone help me figure out where the scripts are going wrong?
Spoiler
Spoiler
Spoiler
clearlistener()
mdlScale = 1.0
if (heapSize < 20000000) then
heapSize = 200000000 -- allow ~ 40 MB instead of just 7.5 MB. Prevents "Runtime Error: Out of scripter memory"
struct weight_data
boneids,weights
struct VertexDeclarationEntry
DataOffset, DataType, EntryType, SubId
struct BoneDData (
BoneID, BoneNameOffset, BoneName, BoneParentID
fn existFile fname = (getfiles fname).count != 0
fn PrintOffset Var =
local Var = Var
print ("This is the offset 0x" + (bit.intAsHex Var) as string)
Var
y = 180
PrintOffset y
x = 200
print ("This is the number 0x" + (bit.intAsHex x) as string)
fn floatSwap2 f =
I = bit.floatAsInt f
h = bit.intashex I
while h.count < 8 do h = "0" + h
s = (substring h 7 2) + (substring h 5 2) + (substring h 3 2) + (substring h 1 2)
bit.intAsFloat (bit.hexasint s)
fn ReadBEword fstream = (
return (bit.swapBytes (readshort fstream #unsigned) 1 2)
fn ReadBEHalfFloat Fstream = (
local BH = readByte Fstream #unsigned
local BL = readByte Fstream #unsigned
local N = BH*256 + BL
local S = floor((mod N 65536) / 32768)
local Ef = floor((mod N 32768) / 1024)
local M = mod N 1024
if (Ef==0)AND(M==0) then return ( (-1.0)^S * 0.0 )
if (Ef==0)AND(M!=0) then return ( (-1.0)^S * 2.0^-14 * (M / 2.0^10) )
if (Ef>0)AND(Ef<31) then return ( (-1.0)^S * 2.0^(Ef-15) * (1 + M/2.0^10) )
if (Ef==31)AND(M==0) then return ( (-1.0)^S * 1/0.0 )
if (Ef==31)AND(M!=0) then return 0 --hack-- should be #inf
)--end fn ReadBEHalfFloat
fn ReadBElong fstream = (
long = readlong fstream
long = bit.swapBytes long 1 4
long = bit.swapBytes long 2 3
return long
fn ImportTextureGenerations mm index texfilename filepath = (
matdata = fopen (filepath + texfilename + ".material") "rb"
fseek matdata 0x04 #seek_set
texcount = ReadBElong matdata
fseek matdata 0x24 #seek_set
--PrintOffset (ftell matdata)
DataBegin = ReadBElong matdata
fseek matdata (DataBegin + 0x18) #seek_set
DataBegin2 = ReadBElong matdata
fseek matdata (DataBegin2 + 0x18) #seek_set
TexBegin = ReadBElong matdata
fseek matdata (TexBegin + 0x18) #seek_set
--mat = standardMaterial()
mat = mm.materialList[index]
mat.name = texfilename
mat.showinviewport = true
mat.twosided = false
--print("Material has " + (texcount as string) + " maps!")
for I = 1 to texcount do (
ddsfile = readstring matdata
ddsdata = readstring matdata
--print("Map " + (I as string) + " is " + ddsdata + " map: " + (ddsfile) + ".dds")
pos = ftell matdata
pos = pos + 0x0C
ex = mod pos 4
if(ex != 0) then (
pos = pos + (4 - ex)
fseek matdata pos #seek_set
--print ddsdata
tm = Bitmaptexture filename:(filepath + ddsfile + ".dds")
tm.alphasource = 2
case ddsdata of
"diffuse": mat.diffuseMap = tm
"displacement": (
mat.bumpMap = tm
mat.bumpMapAmount = 40
"normal": (
mat.bumpMap = tm
"specular": mat.specularMap = tm
"gloss": mat.specularMap = tm
"reflection": mat.reflectionMap = tm
default: ( )
fclose matdata
--msh.material = mat
fn ImportTexture mm index texfilename filepath = (
if(not existFile(filepath + texfilename + ".texset")) then (
return true
texdesc = fopen (filepath + texfilename + ".texset") "rb"
fseek texdesc 0x18 #seek_set
texcount = ReadBElong texdesc
textfiles = #()
fseek texdesc (0x20 + texcount * 4) #seek_set
textfiles[I] = readstring texdesc
--print (textfiles[I])
fclose texdesc
mapdata = fopen (filepath + textfiles[I] + ".texture") "rb"
fseek mapdata 0x24 #seek_set
ddsfile = readstring mapdata
ddsdata = readstring mapdata
fclose mapdata
--print ddsdata
tm.alphasource = 2
case ddsdata of
"displacement": (
mat.bumpMap = tm
"normal": (
mat.bumpMap = tm
default: ( )
fn ImportTextureGenerationsMesh msh texfilename filepath = (
pos = ftell matdata
pos = pos + 0x0C
ex = mod pos 4
if(ex != 0) then (
--print ddsdata
tm.alphasource = 2
case ddsdata of
"displacement": (
mat.bumpMap = tm
"normal": (
mat.bumpMap = tm
default: ( )
fclose matdata
msh.material = mat
fn ImportTextureMesh msh texfilename filepath = (
return true
textfiles = #()
fclose texdesc
mat = StandardMaterial()
fclose mapdata
--print ddsdata
tm.alphasource = 2
case ddsdata of
"displacement": (
mat.bumpMap = tm
"normal": (
mat.bumpMap = tm
default: ( )
msh.material = mat
fn ReadBEfloat fstream = (
return floatSwap2(readfloat fstream)
fname = GetOpenFileName caption:"Open Sonic Model File" types:"Sonic Model File(*.model)|*.model"
if (fname!=undefined) and ((doesFileExist fname)==true) then (
f = fopen fname "rb" --open file in read only format
filepath = GetFilenamePath fname
fseek f 0x04 #seek_set
MeshType = ReadBElong f
CinematicMesh = 0
MorphTargetTable = 0
BoneCount = 0
BoneTableOffset = 0
BoneTableOffset2 = 0
BoneTableOffset3 = 0
ModelType = 0
Extra_Mesh_Area = #()
VertexDataBegin = 0x68
if(MeshType == 2) Then (
print "MeshType 2"
fseek f 0x30 #seek_set
BoneCount = ReadBElong f
BoneTableOffset = ReadBElong f + 0x18
BoneTableOffset2 = ReadBElong f + 0x18
BoneTableOffset3 = ReadBElong f + 0x18
VertexDataBegin = 0x40
fseek f 0x18 #seek_set
else if(MeshType == 4) Then (
print "MeshType 4"
fseek f 0x38 #seek_set
VertexDataBegin = 0x48
) else if(MeshType == 5) Then (
print "MeshType 5"
fseek f 0x20 #seek_set
CinematicMesh = ReadBElong f
MorphTargetTable = ReadBElong f + 0x18
ModelType = ReadBElong f
) else if(MeshType == 2005) Then (
print "MeshType 2005"
fseek f 0x28 #seek_set
fseek f 0x44 #seek_set
else (
throw "Unknown format!"
fclose f
MeshDataOffset = 0
if(ModelType > 0x34) then (
MeshDataOffset = (ModelType - 0x34)
MeshDataOffset = MeshDataOffset - (mod MeshDataOffset 4)
ExtraMeshAreaCount = MeshDataOffset / 4
for I = 1 to ExtraMeshAreaCount Do (
append Extra_Mesh_Area (ReadBELong f + 0x18)
BeforeExtra = ftell f
ExtraMeshCount = 0
Extra_Meshes = #()
fseek f Extra_Mesh_Area[I] #seek_set
ThisAreaExtra = (ReadBELong f)
ExtraMeshCount = ExtraMeshCount + ThisAreaExtra
ThisAreaHead = ReadBELong f + 0x18
for j = 1 To ThisAreaExtra Do (
append Extra_Meshes (ThisAreaHead + (j-1) * 4)
fseek f BeforeExtra #seek_set
MeshCount = ReadBElong f
UnkCount2 = ReadBElong f
AddMeshCount = ReadBElong f
AddMeshBegin =ReadBElong f + 0x18
ExtraMeshCount = ExtraMeshCount + AddMeshCount
for I = 1 to AddMeshCount Do (
append Extra_Meshes (AddMeshBegin + (I-1) * 4)
AlphaMeshCount = ReadBElong f
AlphaMeshBegin = ReadBElong f + 0x18
ExtraMeshCount = ExtraMeshCount + AlphaMeshCount
for I = 1 to AlphaMeshCount Do (
append Extra_Meshes (AlphaMeshBegin + (I-1) * 4)
fseek f BoneTableOffset#seek_set
struct BoneOffset (
BoneTOffset
Bone_Offset_array = #()
for I = 1 to BoneCount Do (
BoneTOffset = ReadBElong f + 0x18
append Bone_Offset_array (BoneOffset BoneTOffset:BoneTOffset)
print Bone_Offset_array
Bone_Data_array = #()
BoneID = -1
for k in Bone_Offset_array Do (
fseek f k.BoneTOffset#seek_set
BoneID += 1
BoneParentID = ReadBElong f
BoneNameOffset = ReadBElong f
BoneName = readstring f
append Bone_Data_array ( BoneDData BoneID:BoneID BoneNameOffset:BoneNameOffset BoneName:BoneName BoneParentID:BoneParentID )
print Bone_Data_array
fseek f BoneTableOffset2 #seek_set
--if CinematicMesh == 1 Do (
--fseek f 0x1#seek_cur
BNArr = #()
enableSceneRedraw()
--disableSceneRedraw()
Bone_root_array = #()
m11 = ReadBEfloat f; m12 = ReadBEfloat f; m13 = ReadBEfloat f; m14 = ReadBEfloat f
m21 = ReadBEfloat f; m22 = ReadBEfloat f; m23 = ReadBEfloat f; m24 = ReadBEfloat f
m31 = ReadBEfloat f; m32 = ReadBEfloat f; m33 = ReadBEfloat f; m34 = ReadBEfloat f
m41 = ReadBEfloat f; m42 = ReadBEfloat f; m43 = ReadBEfloat f; m44 = ReadBEfloat f
tfm = matrix3 [m11,m12,m13] [m21,m22,m23] [m31,m32,m33] [m41,m42,m43]
newBone = bonesys.createbone \
tfm.row4 \
(tfm.row4 + 0.01 * (normalize tfm.row1)) \
(normalize tfm.row3)
newBone.name = Bone_Data_array[I].BoneName
newBone.width = 0.01
newBone.height = 0.01
newBone.transform = tfm
pos = (-1) * [m14,m24,m34]
pos = pos * tfm
--if(newbone.name == "Brow1_L") then
--newBone.pos = [0.045,0.84,0.148]
--else if(newbone.name == "Brow2_L") then
--newBone.pos = [0.096,0.911,0.108]
--else if(newbone.name == "Brow3_L") then
--newBone.pos = [0.138,0.854,0.05]
--else if(newbone.name == "Brow_C") then
--newBone.pos = [0.0, 0.8, 0.05]
--else
newBone.pos.x = pos.x * mdlScale
newBone.pos.y = pos.z * (-1) * mdlScale
newBone.pos.z = pos.y * mdlScale
newBone.setBoneEnable false 0
newBone.pos.controller = TCB_position ()
newBone.rotation.controller = TCB_rotation ()
if (Bone_Data_array[I].BoneParentID != -1) then
newBone.parent = BNArr[Bone_Data_array[I].BoneParentID+1]
BNArr[I] = newBone
if I == 1 do (
append Bone_root_array newBone
MorphArr = #()
MorphArr2 = #()
Morph_Face_array = #()
Morph_Name_array = #()
print "Bones done"
if CinematicMesh == 1 Then (
fseek f MorphTargetTable #seek_set
print "Cinematic mesh"
PrintOffset (ftell f)
MorphVertCountOffset = ReadBElong f + 0x18
MorphVertCount = ReadBElong f
MorphTableEnd = ReadBElong f + 0x18
MorphUnkCount1 = ReadBElong f
MorphCount = ReadBElong f
MorphTableStart = ReadBElong f + 0x18
MorphTableNameStart = ReadBElong f + 0x18
MorphFaceSetsCount = ReadBElong f
MorphFaceTableStart = ReadBElong f + 0x18
Null = readlong f
MorphFaceTableEnd = ReadBElong f + 0x18
Texture = ""
Bone_ids1 = #()
fseek f MorphFaceTableStart#seek_set
MorphFaceSets = #()
MorphVertSize = 0x68
DataTable = #()
for I = 1 to MorphFaceSetsCount Do
FaceSetStart = ReadBElong f + 0x18
append MorphFaceSets FaceSetStart
fseek f MorphFaceSets[I] #seek_set
TextureOffset = ReadBElong f + 0x18
MorphFaceCount = ReadBElong f
MorphFaceOffset = ReadBElong f + 0x18
--ReadBElong f
--MorphVertSize = ReadBElong f
--MorphDataTable = ReadBElong f + 0x18
if ( I == 1) then
BackJump = ftell f
fseek f TextureOffset #seek_set
Texture = readstring f
fseek f BackJump #seek_set
fseek f 0x10 #seek_cur
boneidcount = ReadBElong f
boneidstart = (ReadBElong f) + 0x18
fseek f boneidstart #seek_set
for j=1 to boneidcount do
addboneid = (ReadByte f #unsigned)
append Bone_ids1 (addboneid + 1)
--Read data table
CoordinatesFound = false
UVDataFound = false
BoneIndicesFound = false
BoneWeightsFound = false
DataTableEnd = false
fseek f MorphDataTable #seek_set
PrintOffset(MorphDataTable)
while(not DataTableEnd) do (
DataOffset = ReadBElong f
DataType = ReadBElong f
EntryType = ReadBEword f
SubId = ReadByte f
Padding = ReadByte f
if(DataType != -1) then (
append DataTable (VertexDeclarationEntry DataOffset: DataOffset DataType: DataType EntryType: EntryType SubId: SubId)
if(EntryType == 0) then CoordinatesFound = true
if(EntryType == 1) then BoneWeightsFound = true
if(EntryType == 2) then BoneIndicesFound = true
if(EntryType == 5) then UVDataFound = true
) else (
DataTableEnd = true
if((not CoordinatesFound) or (not BoneWeightsFound) or (not BoneIndicesFound) or (not UVDataFound)) then (
throw "NOOOOO!"
fseek f MorphFaceOffset#seek_set
StartDirection = 1
f1 = (ReadBEword f) + 1
f2 = (ReadBEword f) + 1
FaceDirection = StartDirection
Do (
f3 = (ReadBEword f)
if (f3==0xFFFF) then (
) else (
f3 += 1
FaceDirection *= -1
if (f1!=f2)AND(f2!=f3)AND(f3!=f1) then (
if FaceDirection > 0 then append Morph_Face_array [f1,f2,f3]
else append Morph_Face_array [f1,f3,f2]
f1 = f2
f2 = f3
) while ((ftell f) != (MorphFaceOffset + (MorphFaceCount * 2)))
fseek f MorphTableEnd #seek_set
Vert_array1 = #() --define arrays for verts, normals, UV and Faces
--Normal_array1 = #()
UV_array1 = #()
Weight_array1 = #()
for k = 1 to MorphVertCount Do (
--Ignoring data table for speed reasons!
vx = ReadBEfloat f --read xyz coordinates
vy = ReadBEfloat f
vz = ReadBEfloat f
fseek f 0x24#seek_cur
tu = ReadBEFloat f --read UV float value
tv = ReadBEFloat f * -1
fseek f 0x28#seek_cur
bone1 = readbyte f#unsigned
bone2 = readbyte f#unsigned
bone3 = readbyte f#unsigned
bone4 = readbyte f#unsigned
weight1 = readbyte f#unsigned
weight2 = readbyte f#unsigned
weight3 = readbyte f#unsigned
weight4 = readbyte f#unsigned
w = (weight_data boneids:#() weights:#())
maxweight = 0
if(bone1 != 0xFF) then
maxweight = maxweight + weight1
if(bone2 != 0xFF) then
maxweight = maxweight + weight2
if(bone3 != 0xFF) then
maxweight = maxweight + weight3
if(bone4 != 0xFF) then
maxweight = maxweight + weight4
if(maxweight != 0) then
mxw = 255.0
w1 = weight1 as float
append w.boneids (Bone_ids1[bone1+1])
append w.weights (w1 / mxw)
w2 = weight2 as float
append w.boneids (Bone_ids1[bone2+1])
append w.weights (w2 / mxw)
w3 = weight3 as float
append w.boneids (Bone_ids1[bone3+1])
append w.weights (w3 / mxw)
w4 = weight4 as float
append w.boneids (Bone_ids1[bone4+1])
append w.weights (w4 / mxw)
append Vert_array1 [vx*mdlScale,(-1)*vz*mdlScale,vy*mdlScale]
append UV_array1 [tu,tv,0] --save UVs to UV_array
append Weight_array1 w
msh = mesh vertices:Vert_array1 faces:Morph_Face_array --build mesh
msh.numTVerts = UV_array1.count
buildTVFaces msh
ImportTextureMesh msh Texture filepath
msh.name = "Mouth"
for j = 1 to UV_array1.count do setTVert msh j UV_array1[j]
for j = 1 to Morph_Face_array.count do setTVFace msh j Morph_Face_array[j]
--for j = 1 to Normal_array1.count do setNormal msh j Normal_array1[j]
select $Mouth
MorphMod = morpher ()
addModifier $Mouth MorphMod
$Mouth.morpher.Autoload_of_targets = 1
--$Mouth.parent = $Neck
fseek f MorphTableStart#seek_set
for I = 1 to MorphCount Do (
append MorphArr (ReadBElong f + 0x18)
append MorphArr2 (ReadBElong f + 0x18)
fseek f MorphArr[I]#seek_set
MorphName = readstring f
fseek f MorphArr2[I]#seek_set
Morph_Vert_array = #()
Morph_UV_array = #()
--Morph_Normal_array = #()
vx = ((ReadBEfloat f) ) + Vert_array1[k].x / mdlScale
vy = ((ReadBEfloat f) ) + Vert_array1[k].z / mdlScale
vz = ((ReadBEfloat f) ) + (-1) * Vert_array1[k].y / mdlScale
append Morph_Vert_array [vx * mdlScale,-vz * mdlScale,vy * mdlScale]
msh = mesh vertices:Morph_Vert_array faces:Morph_Face_array --build mesh
buildTVFaces msh
msh.name = MorphName
--for j = 1 to Morph_Normal_array.count do setNormal msh j Morph_Normal_array[j]
append Morph_Name_array msh
max modify mode
select $mouth
skinMod = skin ()
addModifier $mouth skinMod
for I = 1 to BNArr.count do
maxbone = getnodebyname BNArr[I].name
if I != BNArr.count then
skinOps.addBone skinMod maxbone 0
else
skinOps.addBone skinMod maxbone 1
modPanel.setCurrentObject skinMod
for I = 1 to Weight_array1.count do
w = Weight_array1[I]
bi = #() --bone index array
wv = #() --weight value array
for j = 1 to w.boneids.count do
boneid = w.boneids[j]
weight = w.weights[j]
append bi boneid
append wv weight
skinOps.ReplaceVertexWeights skinMod I bi wv
vwld = Vertex_Weld()
vwld.enabledInRenders = true
vwld.enabledInViews = false
vwld.threshold = 0.002
addModifier $mouth vwld
max create mode
for b = 1 to Morph_Name_array.count Do (
WM3_MC_BuildFromNode $Mouth.morpher b Morph_Name_array[b]
hide Morph_Name_array[b]
All_Vert_array = #()
All_UV_array = #()
All_Mat_Face_array = #()
All_Face_array = #()
All_Weight_array = #()
AllVertexCount = 0
MultiMat = MultiMaterial()
MultiMat.numsubs = MeshCount+ExtraMeshCount
fseek f (VertexDataBegin + MeshDataOffset) #seek_set
else
fseek f VertexDataBegin #seek_set
for c = 1 to MeshCount+ExtraMeshCount Do (
CExtra = false
if(c > MeshCount) then (
--Extra mesh!
CExtra = true
extraIndex = c - MeshCount
fseek f (Extra_Meshes[extraIndex]) #seek_set
print("Extra Mesh " + (extraIndex as string))
--print ("Mesh: " + c as string)
--PrintOffset (ftell f)
Vert_array = #()
Normal_array = #()
UV_array = #()
Face_array = #()
Weight_array = #()
BoneID_array = #()
offsetstart = (ReadBElong f) + 0x18
tablestart = ftell f
fseek f offsetstart#seek_set
BackJump = ftell f
--print (Texture)
FaceStart = ReadBElong f + 0x18
VertStart = ReadBElong f + 0x18
DataTableStart = ReadBElong f + 0x18
SecBoneCount = ReadBElong f
SecBoneIDs = (ReadBElong f) + 0x18
BackJump = ftell f
fseek f SecBoneIDs #seek_set
for I = 1 to SecBoneCount do
append BoneID_array (addboneid + 1)
Count10 = ReadBElong f
Count11 = ReadBElong f
FaceStart = ftell f
VerStart = (FaceCount * 2) + FaceStart
--Read data table
BackJump = ftell f
UVDataFound = false
DataTable = #()
fseek f DataTableStart #seek_set
SubId = ReadByte f
) else (
DataTableEnd = true
throw "NOOOOO!"
--end read data table
StartDirection = 1
Do (
f3 = (ReadBEword f)
) else (
f3 += 1
FaceDirection *= -1
if FaceDirection > 0 then append Face_array [f1,f2,f3]
else append Face_array [f1,f3,f2]
f1 = f2
f2 = f3
) while ((ftell f) != (VerStart))
fseek f VerStart#seek_set
test = readshort f
if test != 0x0000 Do (
fseek f -2 #seek_cur
fseek f VertStart#seek_set
for v = 1 to VertCount Do (
vx = 0
vy = 0
vz = 0
tu = 0
tv = 0
bone1 = 0xFF
bone2 = 0xFF
bone3 = 0xFF
bone4 = 0xFF
weight1 = 0
weight2 = 0
weight3 = 0
weight4 = 0
UVSubZeroFound = false
UVFound = false
VertexDataStart = ftell f
for x = 1 to DataTable.count Do (
Entry = DataTable[x]
fseek f Entry.DataOffset #seek_cur
if(Entry.EntryType == 0) Then (
vx = ReadBEfloat f
vy = ReadBEfloat f
vz = ReadBEfloat f
if(Entry.EntryType == 1) Then (
if(Entry.EntryType == 2) Then (
if(Entry.EntryType == 5) Then (
SubId = Entry.SubId
ReadThisUV = (not UVFound) or (not UVSubZeroFound and SubId == 0)
if(ReadThisUV) then (
UVFound = true
if(SubId == 0) then
UVSubZeroFound = true
if(Entry.DataType == 2892709) then (
tu = ReadBEfloat f
tv = ReadBEfloat f
) else (
tu = ReadBEHalfFloat f
tv = ReadBEHalfFloat f
tv = tv * (-1)
fseek f VertexDataStart #seek_set
fseek f VertSize #seek_cur
maxweight = 0
mxw = 255.0
append w.boneids (BoneID_array[bone1+1])
append w.boneids (BoneID_array[bone2+1])
append w.boneids (BoneID_array[bone3+1])
append w.boneids (BoneID_array[bone4+1])
append Vert_array [vx * mdlScale,(-1)*vz * mdlScale,vy * mdlScale] --save verts to Vert_array
--append Normal_array [nx,ny,nz] --save normals to Normal_array
append UV_array [tu,tv,0] --save UVs to UV_array
append Weight_array w
fseek f tablestart#seek_set
for I = 1 to Face_array.count do (
vertices = Face_array[I]
append All_Face_array [vertices[1] + AllVertexCount, vertices[2] + AllVertexCount, vertices[3] + AllVertexCount]
append All_Mat_Face_array c
AllVertexCount = AllVertexCount + Vert_array.count
for I = 1 to Vert_array.count do (
append All_Vert_array vert_array[I]
append All_UV_array UV_array[I]
append All_Weight_array Weight_array[I]
importTexture MultiMat c Texture filepath
/*msh = mesh vertices:Vert_array faces:Face_array --build mesh
msh.numTVerts = UV_array.count
importTexture msh Texture filepath
buildTVFaces msh
for j = 1 to UV_array.count do setTVert msh j UV_array[j]
for j = 1 to Face_array.count do setTVFace msh j Face_array[j]
--for j = 1 to Normal_array.count do setNormal msh j Normal_array[j]
max modify mode
select msh
skinMod = skin ()
addModifier msh skinMod
else
for I = 1 to Weight_array.count do
w = Weight_array[I]
append bi boneid
append wv weight
max create mode*/
max create mode
msh = mesh vertices:All_Vert_array faces:All_Face_array --build mesh
msh.numTVerts = All_UV_array.count
if (BNArr.count >= 1) then msh.name = BNArr[1].name
buildTVFaces msh
for j = 1 to All_UV_array.count do setTVert msh j All_UV_array[j]
for j = 1 to All_Face_array.count do (
setTVFace msh j All_Face_array[j]
setFaceMatID msh j All_Mat_Face_array[j]
max modify mode
select msh
skinMod = skin ()
else
for I = 1 to All_Weight_array.count do
w = All_Weight_array[I]
append bi boneid
append wv weight
msh.material = MultiMat
max modify mode
--enableSceneRedraw()
fclose f
/*select Bone_root_array[1]
scale $ [36.0,36.0,36.0]
rotate $ (angleaxis 90 [1,0,0])*/
--actionMan.executeAction 0 "311" -- Tools: Zoom Extents All Selected
Spoiler
clearlistener()
	-- Script originally written by chroxx, Link, and Kentalin. Modified by Brooks (ItsEasyActually) for Generations :D
struct weight_data
	boneids,weights
struct BoneOffset (
BoneTOffset
struct BoneDataStruc (
	local Var = Var
	Var
y = 180
PrintOffset y
x = 200
fn floatSwap2 f =
	i = bit.floatAsInt f
	h = bit.intashex i
return long
-- TexDir = getSavePath caption:"Select texture path" initialDir:"C:\Users\Experience\Desktop\Emulators\Games\360\Sonic Generations Demo\disk\bb\Packed\ghz100\TexPack"
-- Textures = getFiles (TexDir+"/*.dds")
-- Materials = getFiles (TexDir+"/*.material")
fseek f 0x18#seek_set
MeshHeaderTotal = ReadBELong f
OffsetMHLoc = ReadBELong f + 0x18
for i = 1 to BoneCount Do (
BoneID = -1
BoneID += 1
append Bone_Data_array ( BoneDataStruc BoneID:BoneID BoneNameOffset:BoneNameOffset BoneName:BoneName BoneParentID:BoneParentID )
BNArr = #()
				  tfm.row4	\
			newBone.name   = Bone_Data_array[i].BoneName
			newBone.wirecolor = yellow
			newbone.showlinks = true
			pos = [m14,m24,m34]
			pos = pos * tfm
			newBone.pos.x = (-1)*pos.x
			newBone.pos.y = (-1)*pos.y
			newBone.pos.z = (-1)*pos.z
			if (Bone_Data_array[i].BoneParentID != -1) then
					  newBone.parent = BNArr[Bone_Data_array[i].BoneParentID+1]
			BNArr[i] = newBone
			if i == 1 do (
MorphArr = #()
MorphArr2 = #()
print "Bones done"
Null = readlong f
Bone_ids1 = #()
MorphFaceSets = #()
for i = 1 to MorphFaceSetsCount Do
fseek f MorphFaceSets[i] #seek_set
Offset1 = ReadBElong f	+ 0x18
if ( i == 1) then
StartDirection = 1
Do (
f3 = (ReadBEword f)
) else (
f3 += 1
FaceDirection *= -1
f1 = f2
f2 = f3
Normal_array1 = #()
UV_array1 = #()
Weight_array1 = #()
vy = ReadBEfloat f
vz = ReadBEfloat f
maxweight = 0
		mxw = maxweight as float
append Vert_array1 [vx,vy,vz]
buildTVFaces msh
msh.name =  "Mouth"
select $Mouth
for i = 1 to MorphCount Do (
fseek f MorphArr[i]#seek_set
fseek f MorphArr2[i]#seek_set
vy = ((ReadBEfloat f) ) + Vert_array1[k].y
vz = ((ReadBEfloat f) ) + Vert_array1[k].z
append Morph_Vert_array [vx,vy,vz]
buildTVFaces msh
max modify mode
select $mouth
skinMod = skin ()
for i = 1 to BNArr.count do
	maxbone = getnodebyname BNArr[i].name
	if i != BNArr.count then
	else
for i = 1 to Weight_array1.count do
	w = Weight_array1[i]
		append bi boneid
		append wv weight
	skinOps.ReplaceVertexWeights skinMod i bi wv
max create mode
fseek f OffsetMHLoc#seek_set
for m = 1 to MeshHeaderTotal Do (
MeshHeader = ReadBELong f + 0x18
	NextHeader = ftell f
fseek f MeshHeader#seek_set
MshLoc = ReadBElong f + 0x18
AddMeshBegin = ReadBElong f + 0x18
AlphaMeshCount = ReadBELong f
AlphaMeshBegin = ReadBELong f + 0x18
fseek f 0x4#seek_cur
TestByte = ReadByte f#unsigned
if TestByte != 0xFF Do (
	fseek f -0x5#seek_cur
	OpaqueCount = ReadBELong f
	OpaqueOffset = ReadBELong f + 0x1C
	fseek f OpaqueOffset#seek_set
	OpOff = ReadBELong f + 0x18
	OpaqueMeshBegin = ReadBELong f + 0x18
	fseek f OpOff#seek_set
	OpaqueMeshCount = ReadBELong f
if TestByte == 0xFF Do (
	OpaqueMeshCount = 0
fseek f MshLoc#seek_set
for c = 1 to MeshCount+AddMeshCount+AlphaMeshCount+OpaqueMeshCount Do (
if(c == MeshCount + 1) then (
	fseek f AddMeshBegin #seek_set
if(c == (MeshCount+AddMeshCount) + 1) then (
	fseek f AlphaMeshBegin #seek_set
if(c == (MeshCount+AddMeshCount+AlphaMeshCount) + 1) then (
	fseek f OpaqueMeshBegin #seek_set
	Vert_array = #()
	Normal_array = #()
	UV_array = #()
	Face_array = #()
	Weight_array = #()
	BoneID_array = #()
TexNameOff = ReadBElong f + 0x18
VertEnd = ReadBElong f + 0x18
MaterialCount = ReadBElong f
MaterialCountOffset = ReadBElong f
BackJump = ftell f
for i = 1 to SecBoneCount do
FaceStart = ftell f
StartDirection = 1
Do (
f3 = (ReadBEword f)
) else (
f3 += 1
FaceDirection *= -1
f1 = f2
f2 = f3
 test = readshort f
if VertSize == 0x24 Do (
vy = ReadBEfloat f
vz = ReadBEfloat f
fseek f 0x8#seek_cur
tu = ReadBEHalfFloat f   --read UV float value
tv = ReadBEHalfFloat f * -1
if VertSize == 0x28 Do (
vy = ReadBEfloat f
vz = ReadBEfloat f
fseek f 0xC#seek_cur
if VertSize == 0x2C Do (
vy = ReadBEfloat f
vz = ReadBEfloat f
fseek f 0x10#seek_cur
if VertSize == 0x30 Do(
vx = ReadBEFloat f
vy = ReadBEFloat f
vz = ReadBEFloat f
if VertSize == 0x34 Do (
vx = ReadBEFloat f
vy = ReadBEFloat f
vz = ReadBEFloat f
if VertSize == 0x68 Do (
vy = ReadBEfloat f
vz = ReadBEfloat f
maxweight = 0
append Vert_array [vx,vy,vz] --save verts to Vert_array
fseek f TexNameOff#seek_set
TexName = ReadString f
print TexName
MaterialFile = (filepath+"/")+(TexName+".material")
buildTVFaces msh
msh.name = TexName
max modify mode
select msh
skinMod = skin ()
	if i != BNArr.count then (
	)else(
for i = 1 to Weight_array.count do
	w = Weight_array[i]
		append bi boneid
		append wv weight
mf = fopen MaterialFile "rb"
fseek mf 0x24#seek_set
TextureTable = ReadBELong mf +0x18
fseek mf 0x6#seek_cur
TextureTotal = ReadBEWord mf
-- DiffArr = #()
-- BumpArr = #()
-- SpecArr = #()
fseek mf TextureTable#seek_set
	m = standardMaterial()
for tex = 1 to 1 Do (
	TextureNameOff = ReadBELong mf +0x18
	NextTex = ftell mf
	fseek mf TextureNameOff#seek_set
	fseek mf 0xC#seek_cur
	TextureName = ReadString mf +".dds"
	TexType = ReadString mf as name
	TextureFile = filepath+"/"+TextureName
-- 	print "TextureType ="
-- 	print TexType
-- 	if TexType == "diffuse" Do (
-- 		bt = BitmapTexture()
-- 		bt.FileName = TextureFile
-- 		m.DiffuseMap = bt
-- 	if TexType == "normal" Do (
-- 		nt = BitmapTexture()
-- 		nt.FileName = TextureFile
-- 		append BumpArr[nt]
-- 	if TexType == "specular" Do (
-- 		st = BitmapTexture()
-- 		st.FileName = TextureFile
-- 		append SpecArr[st]
-- 	if TexType == "opacity" Do (
-- 		ot = BitmapTexture()
-- 		ot.FileName = TextureFile
-- 	if TexType == "reflection" Do (
-- 		rt = BitmapTexture()
-- 		rt.FileName = TextureFile
-- 	if TexType == "displacement" Do (
-- 		dt = BitmapTexture()
-- 		dt.FileName = TextureFile
-- 	if TexType == "gloss" Do (
-- 		gt = BitmapTexture()
-- 		gt.FileName = TextureFile
	m.DiffuseMap = bt
	print bt
-- 	fseek mf NextTex#seek_set
-- m.BumpMap = nt
-- m.SpecularMap = st
-- m.OpacityMap = ot
-- m.ReflectionMap = rt
-- m.DisplacementMap = dt
-- m.GlossinessMap = gt
m.showInViewport = true
$.material = m
max create mode
fseek f NextHeader#seek_set
enableSceneRedraw()
fclose mf
fclose f
clearSelection()
Replies (0)
