Cluster Attach, Quick Attach All fails on scrambled/condensed multimaterials
victorEFVH7
Message 1 of 1
victorEFVH7
Im having some issues with attaching objects where the creator have decided to condense the multimaterials so its for example id 1,2,3,4,7,11. When I attach these objects together with other objects where its a full number range in multimaterials or single vraymtl then a few of the objects fails on assigning the correct ID to the elements (see attached image), sometimes it doesnt even attach the material at all.
All attach scripts out there fails on these type of objects with 95% hitrate. The regular poly/mesh attach works as it should in most cases but I cant use this method as it needs to be automated.
I believe the error occur when the multimaterials are condensed but Im not 100% sure if that really is the issue.
Replies (0)
