Closing rendered frame window
Hey guys,
I'm creating a script that contains a render button, but I can't seem to find documentation on how the close the rendered frame window and / or render in it.
Whenever I use the render() command it creates its own RFW (which is 16-bit and I'd like to use the 32-bit one with mental ray). I'd like to use the regular one but can't seem to find out how to control it or render to it.
Can someone point me in the right direction on this?
Cheers,
M.
barigazy
You can use
render outputHDRbitmap:true
Thanks, that solves the 16-bit framebuffer issue!
Still getting duplicate buffers though, I'd like to render in the main one. (with the mr controls)
M.
barigazy
Then you not need to use render fn
Try simply like this
mr = renderers.current
if getclassname mr != "mental ray Renderer" do mr.FrameBufferType = 1
max quick render
Ah, the max quick render command is what I was looking for... 🙂
Thanks!
M.
