checkbox not updating in the Rollout correctly?
Quick Question...
If I have a checkbox in a rollout with a button that is pressed, which is designed to invert the state of the checkbox no matter whether the checkbox is ticked ON or OFF, why does the following code not work?
on SelectInvert pressed do
if cb_wrl.state = true then
cb_wrl.checked = false
else cb_wrl.checked = true
Mike
Because with if statements you should use the compare operator == and not the assign operator =
if cb_wrl.state == true then -- can also be "if cb_wrl.state then etc..."
else
-Johan
also note that .state and .checked are basically the same thing. You should use one or the other in your script to make it more readable (i suggest using "checked" as "state" is too much like "triState")
I agree 🙂
-Johan
Steve_Curley
According to the Help, the TriState property is the only one (of the 3) which says "Get/Set" so use that.
0=unchecked, 1=checked, 2=indeterminate (grey/checked).
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
