Announcements
Change Handlers and modifier attributes (MaxScript)
stalkerportal1
stalkerportal1
seems like Change Handlers is broken in max 2021.1 for modifiers attribute - "name" (in max 2016 - 2019 works)
example:
obj = box()
deleteAllChangeHandlers id: #CH_test
modif = Bend()
when name modif change id:#CH_test do
print "1"
addModifier obj modif
select obj
Changing modifier name from modpanel not trigger change handler. With objects works - ok, but not with modifiers.
denisT.MaxDoctor
that this does not work is very unlikely ... you are doing something wrong.
try execute:
	b = bend()
	h = when name b changes do (print ("name:" + b.name))
	b.name = "the bend"
it must return:
"name:the bend"
"the bend"
does it work? it has to print on Undo/Redo as well
stalkerportal1
I checked it in max 2021.1 and change handler not works as expected 😞
max 2021.1 result(not correct):
max 2019.3 result(correct):
denisT.MaxDoctor
This is very bad. Autodesk should tell us what is going on.
