Camera render failed at specific position or high output resolution
futengda
Message 1 of 9
futengda
I am developing a feature for programmatically placing camera positions. Strangely, I found that when the camera appears at specific angles, the rendering fails and throws a "Known system exception":
```log
-- Known system exception
-- Desc: EXCEPTION_ACCESS_VIOLATION The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
I have test on Max2023 and Max2020, both of them have the same issue.
The AI spam filter always deletes my posts, so I have to split them into several parts to post.
Replies (8)
Message 2 of 9
futengda
part1
Here are some test cases based on the attached max file(3 camera):
  • camera1:the origin issue camera [853.087463,853.087402,696.542969]
  • camera2: move a lot from origin camera1's position [853.087463,853.087402,19.429382],
  • camera1ReduceFloatPrecision: same with camera1 but reduce precision [853.086975,853.086975,696.543030]
    it's position was set using copied text like this, not directly using the variable:futengda_0-1721808430279.giffutengda_1-1721808438802.jpeg
Message 3 of 9
futengda
part2
So, the test results are:
Displaying only $some-complex-object:
1. Rendering fails: `render camera:$camera1 outputsize: [1024,1024]`
2. Rendering succeeds: `render camera:$camera1 outputsize: [512,512]`
3. Rendering succeeds: `render camera:$camera2 outputsize: [1024,1024]`
4. Rendering succeeds: `render camera:$camera1ReduceFloatPrecision outputsize: [1024,1024]`
Displaying only $some-simple-object:
5. Rendering succeeds: `render camera:$camera1 outputsize: [1024,1024]`
So, it is very strange that the failure seems to be related to the camera position, the rendering resolutionthe complexity of the rendered object, and even the float precision
System Info:
  1. Max 2023.3.4
  2. Windows11
  3. 16GB RAM
  4. i5-11260H @ 2.60GHz 2.61 GHz
  5. GPU1: Intel(R) UHD Graphics
  6. GPU2: NVIDIA RTX3050 Laptop (latest driver)
Message 4 of 9
denisT.MaxDoctor
If you want as many people as possible to help you, save the example scene in the most commonly used version—probably 2020 today. But hey, if it's a topic for a select few, go ahead and save the scene in the 2025 version.
Message 5 of 9
futengda
Okay, I have uploaded the 2023 and 2020 versions of the max files.
Message 6 of 9
denisT.MaxDoctor
Yes, I can confirm that the render from camera1 is not working.
Well... but what's the problem? Call it an “unexplained non-anthropogenic phenomenon”, mod the camera a bit, and forget about it...
ooh... "mod the camera a bit, and forget about it..." sounds like lyrics. 😊👍
Message 7 of 9
futengda
Haha, this is somewhat inelegant. For now, I have to manually reduce the floating-point precision to temporarily bypass this issue.
Message 8 of 9
denisT.MaxDoctor
Inelegant? Inelegant is when, after a month of investigation, you are fired for not doing your job. 😜
Message 9 of 9
futengda
Haha, you are right. Let's leave this issue here. I hope it will be helpful to others.
