Announcements
Camera Match Tool source code
sukoy27k
sukoy27k
Are there any chance to get the source code for that plugin? https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/3DSMa...
The plugin should be cammatch.dlu and in the sdk is not present.
I'd like to add support for physical camera, to match photo with "lens shift, both vertical and horizontal".
Of course I will release the update to the autodesk after done.
sukoy27k
Ok it seems I can't get the code.
At least there is a way to cooperate with the plugin? c++ or maxscript as well?
Please I don't want to recode the same ui, as is, it should works for me.
I only need to test some different camera match making algorithms.
zpetersenF4WH3
@sukoy27kdid you ever get anywhere with this? I wanted to form into the Camera Match utility with a script to dissable all campoints intead of having to go through each one and disable manually before assigning new ones.
Such an annoying task when you have 100 campoints in a scene.
sukoy27k
Yes they gave me part of code related to the ui, contact support and ask.
