Camera Animation by CSV
I have a list of camera positions(XYZ) I would like to duplicate in 3DS MAX.  I would like these to import so that the first point in the list is frame 1 camera position and then the next point in the list is the camera position for frame 2 and so on until the end of the CSV.  Anyone know a way to do this quickly?
leeminardi
Turn on the Maxscript  Listener and see what commands are generated for a camera move.  You will also need to consider the rotation of the camera as well.  For example, a move in frame 4 coupled with a rotation about the x and y axes would look something like this:
sliderTime = 4f
move $ [31.9392,11.5601,0]
rotate $ (angleaxis 15.5 [1,0,0])
rotate $ (angleaxis -26 [0,1,0])
You could easily create this script in Excel from your data using the concatenate function.
lee.minardi
sliderTime = 4f
I believe this will work.  I'll give it a try today.  FYI, what i'm working on is a 360° video i have recorded and i have very precise coordinates for the camera location for each frame of the video.  I am wanting to augment this video with geographically correct info or objects (like Road Centerline Stations, ect.).  I was able to do this yesterday with a path created from these coordinates, so i think i may have 2 ways to do this now.  here is a proof of concept render I did Yesterday.
https://youtu.be/YxlBT67GoB8
This is a "VR" clip and you can spin the video around with your mouse or by moving your mobile device if you are viewing it that way.  Again, thanks for your reply.
leeminardi
Slick!
lee.minardi
