C# transform controller SetValue not working
MehdiZangenehBar
MehdiZangenehBar
I’m trying to set value for a node’s transform controller, but not working:
using Autodesk.Max;
using System.Windows;
namespace TestLibrary
    public partial class TestWindow : Window
        private readonly static IGlobal globalInterface = GlobalInterface.Instance;
        private readonly static IInterface coreInterface = globalInterface.COREInterface;
        private void Button_Click(object sender, RoutedEventArgs e)
            int time = coreInterface.Time;
            IINode selNode = coreInterface.GetSelNode(0);
            if (selNode == null) MessageBox.Show("Selection empty.");
            else
                IMatrix3 matrix = globalInterface.Matrix3.Create(true);
                selNode.TMController.SetValue(time,matrix,true,GetSetMethod.Absolute);
                globalInterface.COREInterface.RedrawViews(time, RedrawFlags.Normal, null);
        public TestWindow()
            InitializeComponent();
g.SuspendAnimate();
g.AnimateOn();
//you set value code
node.SetNodeTM(t, node_tm);
g.ResumeAnimate();
