c++ pivot problems
c++ pivot problems
c++ pivot problems
I thought I might if had this working. But no -sigh
It looks to me moving my pivot sometimes if the object is not scaled. Then its a mess.
I'm I doing this right?
ip = GetCOREInterface();
ip7 = GetCOREInterface7();
// switch to pivotCenter from max script -- couldn't find in SDK
ExecuteMAXScriptScript(_T("toolMode.pivotCenter()"), 0, 0);
Box3 bb;
ViewExp& vpt = ip->GetViewExp(NULL);
for( auto i = 0; i < ip->GetSelNodeCount(); i++){
	INode *newnode = ip->GetSelNode(i);
	Object *obj = newnode->GetObjectRef();
	obj->GetLocalBoundBox(ip->GetTime(), newnode, vpt.ToPointer(), bb);
	Point3 theBox(bb.Center().x, bb.pmax.y, bb.pmin.z );
	Matrix3 mat(1);
	newnode->ResetPivot(ip->GetTime());
	newnode->Move(ip->GetTime(), mat, theBox, TRUE, FALSE, PIV_PIVOT_ONLY, FALSE);
	newnode = NULL;
ip->RedrawViews(ip->GetTime());
I guess what I'm after is the c++ way to ....
obj.pivot = [obj.min.x, obj.center.y, obj.center.z]
thanks for any thoughts on this
haw
Did you find an answer to this? I'm doing C# but have the same question....
haw
I think I got it to work... this is c# but simple enough to translate...
node.CenterPivot(intfc.Time, false); //The missing call you didn't have access to?
IMatrix3 tm2 = global.Matrix3.Create();
tm2.IdentityMatrix();
IBox3 bb = objOriginal.GetLocalBoundBox(intfc.Time, node, intfc.GetViewExp(IntPtr.Zero));
IPoint3 pnt = global.Point3.Create();
pnt.X = bb.Center.X;
pnt.Y = bb.Center.Y;
pnt.Z = bb.Min.Z;
node.Move(intfc.Time, tm2, pnt, true, false, (int)Autodesk.Max.PivotMode.PivotOnly,false);
istan
