Announcements
C++ Gamma
C++ Gamma
kotorotomoto
Message 1 of 11
C++ Gamma
kotorotomoto
Hi everyone.
Does anyone know how to enable Override Gamma and set the value? I spent a lot of time trying to get to it through IParamBlock2, but to no avail.
Or similarly with maxscript (openBitmap @"d:\text.png" gamma:1.0)
Any ideas?
Replies (10)
Message 2 of 11
denisT.MaxDoctor
What does IPramBlock2 have to do with the Bitmap gamma?
Message 3 of 11
kotorotomoto
I tried using BitmapInfo
BitmapInfo biLoad(finalFn);
biLoad.SetCustomGamma(TRUE);
biLoad.SetGamma(overrideGamma);
but to no avail.
The AI ​​insisted on messing with IPramBlock2.
Message 4 of 11
denisT.MaxDoctor
Screw AI 😁 ... there's no param block in Bitmap.
Now, what do you really want to do? Do you want to change the gamma for some Bitmap? Or do you want to create a Bitmap with a specified gamma?
Message 5 of 11
kotorotomoto
Both. I want to change the incorrect ones and set the gamma when creating a Bitmap.
Message 6 of 11
denisT.MaxDoctor
Why do you think that simply changing the gamma can change the Bitmap?
If you know how to do this via MXS, just call MXS from the C++ SDK.
Message 7 of 11
kotorotomoto
It will work, but it's a kludge. I'd like to figure it out.
Message 8 of 11
denisT.MaxDoctor
If you want to figure out how it all works yourself, just do it. It's not entirely clear, but everything is explained in bitmap.h.
Message 9 of 11
kotorotomoto
Thanks for pointing me in the right direction.
It worked!
Message 10 of 11
denisT.MaxDoctor
If you ask others for help in finding a solution, it is considered good practice on professional forums that even if you found it yourself, you should publish it so that others can use it.
Message 11 of 11
kotorotomoto
Almost the same as I tried initially:
biLoad.SetCustomFlag(BMM_CUSTOM_GAMMA);
biLoad.SetCustomGamma(overrideGamma);
