C# Biped
C# Biped
MehdiZangenehBar
C# Biped
MehdiZangenehBar
Anyone can show me how we can get biped interface inside C# using autodesk.max.dll? This is an example that GetInterface return null:
using System.Windows;
using Autodesk.Max;
namespace TestLibrary
    public static class TestClass
        private readonly static IGlobal globalInterface = GlobalInterface.Instance;
        private readonly static IInterface coreInterface = globalInterface.COREInterface;
        public static void TestFunction()
            IINode node = coreInterface.GetSelNode(0);
            IBipMaster iBipMaster = node.TMController.GetInterface((InterfaceID)0x9165) as IBipMaster;
            if (iBipMaster == null) MessageBox.Show("null");
MehdiZangenehBar
Anyone has experience to use biped class in C#?
Swordslayer
Type conversions in C# often have to be done via marshalling:
using Autodesk.Max.Wrappers;
public static Autodesk.Max.IBipMaster TestFunction()
	var ptr = ((INativeObject)node.TMController.GetInterface((InterfaceID)0x9167)).NativePointer;
	return (Autodesk.Max.IBipMaster)Autodesk.Max.Wrappers.CustomMarshalerBipMaster.GetInstance(string.Empty).MarshalNativeToManaged(ptr);
MehdiZangenehBar
Which version do you use? I want to support 2018 and above. I'm looking for "IIBipMaster", not "IBipMaster".Based on your example, following code should work, right?
using Autodesk.Max;
            IIBipMaster bipInterface = (IIBipMaster)CustomMarshalerBipMaster.GetInstance(string.Empty).MarshalNativeToManaged(ptr);
            MessageBox.Show(bipInterface.NumFingers.ToString());
But it will crash the max.
MehdiZangenehBar
I found this solution from the biped API:
using Autodesk.Max;
            IIBipMaster bipInterface = globalInterface.IBipMaster12.GetBipMaster12Interface(node.TMController);
But I just wondering why IBipMaster API is not exist in the GlobalInterface, like this:
IIBipMaster bipInterface = globalInterface.IBipMaster.GetBipMasterInterface(node.TMController);
Swordslayer
You had IBipMaster in your original code so I gave you that. Anyway, change CustomMarshalerBipMaster to CustomMarshalerIBipMaster and you should be there (works as expected in 2021).
