Bitmap Output Amount, Offset, RGB Level and Premultiplied Alpha
robert3dsmax
robert3dsmax
Dear all,
I am tearing my hairs out trying to figure out how the Bitmap Operators work. I want to create them in a hlsl shader and try to figure out how it works:
Here is what I have got for Output, Offset and rgb Level:
Bitmap.rgb *= rgbLevel;
Bitmap.rgb = clamp(Bitmap.rgb + offset * Bitmap.a, 0, 1);
Bitmap.rgba = Bitmap.rgba * outputAmount;
The Output amount seams not to be correct, the Color is different from the Max material.
Does anybody know where I can find the resources how 3dsmax treats the Bitmap internally?
Thank you much
Robert
Is the output of your shader just darker/brighter than the Max material? Then you'll probably need to do gamma correction
float gamma = 2.2;
Bitmap.rgb = pow(Bitmap.rgb, vec3(1.0/gamma));
robert3dsmax
Thank you for your answer and my very late reply. I fixed it that time (I hope), the order is important as well:
//rgbLevel:
bitmap.rgb =  bitmap.rgb * rgbLevel;
//offset:
bitmap.rgb = bitmap.rgb + offset * bitmap.a;
//outputAmount:
bitmap.rgba = bitmap.rgba * outputAmount;
//inbetween clamp:
bitmap.rgba = clamp(bitmap.rgba, 0.0, 1.0);
//invert
bitmap.rgb = 1.0 - bitmap.rgb;
//clamp
bitmap.rgba = clamp(bitmap.rgba, 0, 1);
//alpha from rgb Amount
bitmap.a = (bitmap.r + bitmap.g + bitmap.b) / 3.0;
