Announcements
BakeToTexture setImageType and pngio
andres.hernandezB63FL
Hi everyone!,
I'm working on an script that uses BakeToTexture utility but I'm stucked when setting the file output options.
In the documentation I found this part:
So, lets say that I have my map created like this:
myNormalMap = BakeToTexture.addMapByTypeName myObject #Normal
 if I try to access to image size I have no problem:
myNormalMap.setImageSize()
but if I try to access to set image type I get this error:
myNormalMap.setImageType()
-- Unknown property: "setImageType" in <MixinInterface:BakeToTextureMap>
 Also, I tried to apply some of the pngio settings to my map but it doesn't seems to have any effect:
pngio.setType #true48
pngio.setAlpha true
myNormalMap.applyImageTypeSettings()
 I really hope someone could give me some help with this.
Thanks a lot!
Swordslayer
Probably outdated code sample, instead of
map1.setImageType "png"
map1.setFilename "Map1"
you should use
map1.fileType = "png"
map1.fileName = "Map1"
You can see all the interface methods/properties by calling showInterface on the map.
Hi Vojtěch, thank you for your response. I guess I can report this as a documentation issue.
About the pngio, do you know how to use that? because it doesn't update the map. I don't know how that works because when you set the pngio it doesn't make any reference to the map, only when you use the apply method.
Thanks a lot
So I tried to set those before creating the map, so it seems that I can't update the map PNG settings after it was created
jmdvella
When changing any of the png to Greyscale they all render greyscale. Same with 24bit RGB. Is this a Bake To Texture limitation?
