Announcements
Bake To Texture - Gamma Setting not accessible?
victorEFVH7
victorEFVH7
Im having some issues accessing the gamma settings in the new bake to texture utility map options section.
It looks like its not a part of the filename as it was in the render to texture utility.
filename:"something.exr" gamma:#auto
And it doesn't appear in the
BakeToTextureMap.getOptionsCount()
 Anyone have a clue of how I can access this parameter so I can save it out in correct gamma trough maxscript?
denisT.MaxDoctor
what is
BakeToTextureMap
victorEFVH7
@denisT.MaxDoctor
Bake to Texture is following
Interface: BakeToTexture
This interface provides access to the functionality of the Bake to Texture dialog, including output file options, file types and sizes, and the baking process. The BakeToTextureMap interface (described below) exposes the functionality of individual bake maps themselves.
https://help.autodesk.com/view/MAXDEV/2022/ENU/?guid=GUID-BC5AE8EA-A88C-4CF3-AF63-4C45FB48EEB5
victorEFVH7
To clarify which parameter im trying to access.
denisT.MaxDoctor
Hmm... that's how it happens... in MAX 2020 this is not yet, but in MAX 2023 it is no longer there. Unfortunately I can't help you as other versions are not my priority.
denisT.MaxDoctor
Oh! Got it...
map = BakeToTexture.addMap $ #DiffuseMap
map.useGammaOverride = true
map.gammaOverrideValue = 2.2
it a property of map
victorEFVH7
Thanks @denisT.MaxDoctor , the property list solved everything
