Announcements
Attach Visible objects with same material by 300
n_rangelov
Message 1 of 16
n_rangelov
Hello  i  modified a little bit  the  original script ( Attach by Same Material  )
,so it will attach only the  visible objects in the scene .
I have the following script
on attach pressed do
if selection.count == 0 then (messageBox "Nothing selected. To use, select one object and run the script to attach all other objects with the same material.")
else if selection.count == 2 then (messageBox "Multiple objects selected. To use, select one object and run the script to attach all other objects with the same material.")
else if selection.count == 1 then
mainobject = $
macros.run "Modifier Stack" "Convert_to_Poly"
mat = mainobject.material
for o in objects where not o.isHiddenInVpt do
--print o.material
if o.material == mat then
-- print "yes"
mainobject.EditablePoly.attach o mainobject
But cannot figure it out ,how  to  make the attach to be by 300 objects in one part   - similar to the  "quick attach  ".
Replies (15)
Message 2 of 16
denisT.MaxDoctor
fn attachAllToOneByMaterial node:selection[1] =
	if iskindof node Editable_Poly do
		for n in geometry where not n.isHiddenInVpt and n != node and n.mat == node.mat do polyop.attach node n
		node
/******* just run with selected target object
attachAllToOneByMaterial()
We could, of course, add some "foolproof" tests, or use some smarter method for a quick attach, but everything should work as it is.
Message 3 of 16
n_rangelov
Hello and thanks for the fast answer.
It's working,  but  how can i make it to go by batches of  300 objects  and then finishing in one.
Thanks again
Message 4 of 16
denisT.MaxDoctor
fn attachAllByCount count:100 mat: nodes: =
	if nodes == unsupplied do nodes = for node in geometry where not node.isHiddenInVpt collect node
	if iskindof mat Material do
		nodes = for node in nodes where node.mat == mat collect node
	InstanceMgr.MakeObjectsUnique nodes #individual
	targets = #()
	target = undefined
	for k=1 to nodes.count while not keyboard.escPressed do
		if (mod k count) == 1 then
			target = nodes[k]
			converttopoly target
			append targets target
			format ">> %\n" (formattedPrint targets.count format:"04d")
		else
			polyop.attach target nodes[k]
	targets
-- You have to specify the target material yourself
-- >>> For example:
m = objects[1].material
--  You have to specify number of group to attach, material, and nodes
-- >>> By default all visible nodes that maches a specified material are used
attachAllByCount count:100 mat:m
Message 5 of 16
denisT.MaxDoctor
For very large scenes, you need a better attachment algorithm (which exists) and perhaps some user interface for "entertaining" during the process (e.g. add a progress bar).
Message 6 of 16
n_rangelov
I did modify it like that
but now i have an issue when i pick a object without material
all visible objects ( with or without material ) are attached to the first object  .
fn attachAllByCount count:100 mat:m  nodes: =
targets = #()
target = undefined
target = nodes[k]
else
targets
-- >>> For example:
m = $.material
Message 7 of 16
denisT.MaxDoctor
you have a different problem... you don't read what I write to you in comments and don't try to understand how the code works.
Message 8 of 16
n_rangelov
I read everything  that you wrote twice. To  be honest i did my best to understand the code and i am sorry couldn't .
And before i post it here i was trying to do it by myself  but couldn't  do it.
Message 9 of 16
denisT.MaxDoctor
Message 10 of 16
n_rangelov
I already changed  that line from :
to
m = $.material
Message 11 of 16
denisT.MaxDoctor
Comment out this line if you want to treat any mat value, including undefined, as a condition.
Message 12 of 16
n_rangelov
Thank you for your help  i got to here.
 For progress bar i have no idea .
try destroyDialog same catch()
rollout nosel "" width:230 height:80
label typeH2U02 "
First select object and then run the script.
width:230 height:50 align:#left
createDialog nosel
z=300
fn attachAllByCount count:z  mat:  nodes: =
targets = #()
target = undefined
target = nodes[k]
else
targets
-- >>> For example:
m = $.material
rollout same "Attach by Same Material" width:260 height:330
label typeH2U02 "
Attach all Visible objects by the same Material.
width:230 height:60 align:#left
Group "How to Use"
label typeH2U04 "
After selecting a object and pressing the Attach button
all visible objects in the viewport (sharing the same material ),
will be attached to the original object.
width:230 height:100 align:#left
spinner 'spn1' "Number of elements" pos:[6,205] width:100 height:16 enabled:true range:[1,400,300] type:#integer align:#left
button attach "Attach" width:100 height:50 align:#center
z= same.spn1.value
 attachAllByCount count:z  mat:m
if selection.count != 0 then (
try destroyDialog nosel catch() ;
createDialog same ;
Message 13 of 16
denisT.MaxDoctor
what is the point of attaching objects by groups of a certain count?
I can understand the idea of collecting by the maximum number of vertices or elements, or by the bounding box, by the world region... but the number of members... why? what for?
Message 14 of 16
denisT.MaxDoctor
@n_rangelov wrote:
use this button
to insert the code
Message 15 of 16
n_rangelov
I was told that when attaching a big scene that way is using less memory .
Message 16 of 16
denisT.MaxDoctor
Who cares about memory these days?
But if you want to better organize a scene, there are groups, containers, xref scenes.... Attaching is a last resort. Very often it is much easier to assemble something than to disassemble it back.
