Announcements
animation problem
animation problem
animation problem
Hello. I'm new here and fairly new to Maxscript.
I have been working on an importer script to import 3 different files into max: a mesh file, a bone file, and an animation file.
I've successfully completed the first two (I think) but I have run into problems getting the animation right.
f = getOpenFileName caption: "Import Animation" types: "Animation (*.ani)|*.ani"
ReadANI f &Animation
For BoneID = 1 To Animation.BoneData.names.Count Do
obj = getnodebyname Animation.BoneData.names
if obj != undefined Then
If Animation.BoneTM == undefined Then
tm = Animation.BoneTM
For FrameID = 1 To Animation.FrameCount Do
rot = Animation.BoneFrame.Rotation
trans = Animation.BoneFrame.Translation
animate on
at time FrameID (obj.pos = trans; obj.rotation = rot)
else
if tm != undefined Then obj.transform = tm
as you can see the problem lies within the animate on code block. I have a series of positions and rotations for each bone in each frame. Given that the bones have parents or are a child of parents. The model has a skin modifier with the bones added in. I had to do that manually as I am still working on it.
My question is am I doing something wrong with the animation because it gives weird results. I have a picture to illustrate the problem better
I can't tell precisely what is wrong here unless I see how you are storing your rotation and translation, I only see how you are applying it. From what I can tell it may not work out as easily as you have it written. I've found the best way to store animation is capturing each keyframe for position and rotation individually then storing the transforms for all the keys. However, just storing the world transform may not be sufficient. If I know the bone has a parent and will continue to have a parent I will store an offset matrix of that transform in parent space. This will generally get exactly what I want. Additionally, after all the transforms are set you can go back through and remove the specific translation, rotation, scale keys that may have been created, where you don't want them, as a result of setting the transforms. That requires another step but is really only a cleanup.
Pseudo Code:
fn get_bone_animation bone =
-- get each translation keyframe
anim_keys = #()
for i in bone.controller.position.controller.keys do append anim_keys i.time
-- get each rotation keyframe
for i in bone.controller.rotation.controller.keys do appendifunique anim_keys i.time
-- store the bone transform for every frame there is a key
anim_transforms = #()
for i in anim_keys do (
at time i (
if bone.parent == undefined then (
-- world space transform
append anim_transforms bone.transform
) else (
-- parent space transform
append anim_transforms (bone.transform * inverse bone.parent.transform)
return anim_transforms
fn set_bone_animation bone transforms =
for i in transforms do (
with animate on (
-- you will have to capture your time somewhere probably in your structure
at time (
-- apply transforms
bone.transform = transforms
) else (
bone.transform = (transforms * bone.parent.transform)
I will try to incorporate what you said into my script. In the meantime here is the functions for reading and storing the animation file. I want to let everyone know that this format is based on the ASE format but with some differences. People familiar with ASE will spot the similarities.
Function ReadCHR FileName &BoneData &Version =
If FileName == Undefined Then Return False
BoneData = ClsBoneData()
Local FileHandle = 0
Local I = 0
FileHandle = FOpen FileName "rbS"
Version = ReadLong FileHandle #Unsigned
If Version < 4 Then
MessageBox "Invalid Version, attempting to continue anyway."
BoneData.ID = ReadLong FileHandle #Unsigned
BoneData.BoneCount = ReadLong FileHandle #Unsigned
CreateArray &BoneData.Names BoneData.BoneCount
CreateArray &BoneData.TM BoneData.BoneCount
CreateArray &BoneData.InverseTM BoneData.BoneCount
CreateArray &BoneData.LocalTM BoneData.BoneCount
CreateArray &BoneData.Parents BoneData.BoneCount
For I = 1 To BoneData.BoneCount Do
FSeek FileHandle 4 #Seek_Cur --Bone Name Len
BoneData.Names = ReadString FileHandle
BoneData.TM = ReadMatrix FileHandle
BoneData.InverseTM = ReadMatrix FileHandle
BoneData.LocalTM = ReadMatrix FileHandle
BoneData.Parents = (ReadLong FileHandle #Signed) + 1
If (FindString BoneData.Names "L ForeArm") != Undefined Then BoneData.LeftArmIndex = I
Else If (FindString BoneData.Names "R ForeArm") != Undefined Then BoneData.RightArmIndex = I
Else If (FindString BoneData.Names "L Hand") != Undefined Then BoneData.LeftHandIndex = I
Else If (FindString BoneData.Names "R Hand") != Undefined Then BoneData.RightHandIndex = I
BoneData.SendVS = ReadLong FileHandle #Unsigned
BoneData.LocalRH = ReadMatrix FileHandle
BoneData.LocalShield = ReadMatrix FileHandle
BoneData.LocalKnuckle = ReadMatrix FileHandle
If Version == 5 Then
CreateArray &BoneData.Events 4
CreateArray &BoneData.EventParents 4
For I = 1 To 4 Do BoneData.Events = ReadVector3 FileHandle
For I = 1 To 4 Do BoneData.EventParents = ((ReadLong FileHandle #Signed) + 1)
If Version >= 6 Then
CreateArray &BoneData.Events 8
CreateArray &BoneData.EventParents 8
For I = 1 To 8 Do BoneData.Events = ReadVector3 FileHandle
For I = 1 To 8 Do BoneData.EventParents = ((ReadLong FileHandle #Signed) + 1)
If Version == 7 Then
BoneData.LocalLH = ReadMatrix FileHandle
FClose FileHandle
Function ReadANI FileName &ANI =
Ani = ClsAnimationData()
Local Version = 0
Local FrameCount = 0
Local BoneCount = 0
Local PathPresent = 0
Local EventCount = 0
Local I = 0
ANI.Name = GetFilenameFile FileName
If Version != 10 Then
ANI.ID = ReadLong FileHandle #Unsigned
ANI.PerSLERP = ReadFloat FileHandle
FSeek FileHandle 32 #Seek_Cur
FrameCount = ReadLong FileHandle #Unsigned
ANI.FrameCount = FrameCount
PathPresent = ReadLong FileHandle #Unsigned
If PathPresent != 0 Then FSeek FileHandle (12 * FrameCount) #Seek_Cur
ReadTM FileHandle &ANI BoneCount FrameCount
CreateArray &ANI.Attribs FrameCount
For I = 1 To FrameCount Do
ANI.Attribs = ClsAttributes()
ANI.Attribs.Flags = ReadLong FileHandle #Unsigned
ANI.Attribs.SoundID = ReadLong FileHandle #Unsigned
ANI.Attribs.Frame = ReadFloat FileHandle
EventCount = ReadLong FileHandle #Unsigned
If EventCount != 0 Then
CreateArray &ANI.Events EventCount
For I = 1 To EventCount Do ANI.Events = ReadVector3 FileHandle
Function ReadTM FileHandle &AnimationData TotalBones TotalFrames =
Local NameLength = 0
Local PoolSize = 0
Local AnimationPresent = 0
Local I = 0
Local J = 0
AnimationData.BoneData = ClsBoneData()
AnimationData.FrameCount = TotalFrames
AnimationData.BoneData.BoneCount = TotalBones
CreateArray &AnimationData.BoneData.Names TotalBones
CreateArray &AnimationData.BoneData.TM TotalBones
CreateArray &AnimationData.BoneData.InverseTM TotalBones
CreateArray &AnimationData.BoneData.LocalTM TotalBones
CreateArray &AnimationData.BoneData.Parents TotalBones
For I = 1 To TotalBones Do
AnimationData.BoneData.Names = ReadString FileHandle
AnimationData.BoneData.InverseTM = ReadMatrix FileHandle
AnimationData.BoneData.LocalTM = ReadMatrix FileHandle
AnimationData.BoneData.Parents = ((ReadLong FileHandle #Signed) + 1)
--Generate TM matrix to fill out the whole structure
AnimationData.BoneData.TM = Inverse AnimationData.BoneData.InverseTM
FSeek FileHandle 4 #Seek_Cur --Skip PoolSize
CreateArray &AnimationData.BoneTM TotalBones
CreateArray &AnimationData.BoneFrame TotalBones
AnimationPresent = ReadLong FileHandle #Unsigned
If AnimationPresent != 1 Then
AnimationData.BoneTM = ReadMatrix FileHandle
Else
CreateArray &AnimationData.BoneFrame TotalFrames
For J = 1 To TotalFrames Do
AnimationData.BoneFrame = ClsFrame()
AnimationData.BoneFrame.Rotation = ReadQuaternion FileHandle
AnimationData.BoneFrame.Translation = ReadVector3 FileHandle
Function ReadTMAni FileHandle &GeometryObject FrameCount =
Local FramePresent = ReadLong FileHandle #Unsigned
Local I = 0
If FramePresent != 0 Then
CreateArray &GeometryObject.StaticFrames FrameCount
GeometryObject.StaticFrames = ClsFrame()
GeometryObject.StaticFrames.Rotation = ReadQuaternion FileHandle
GeometryObject.StaticFrames.Translation = ReadVector3 FileHandle
still no luck getting animation to work. would love to see if anyone has a solution to this problem.
paulneale
With it all left justified it is very hard to read it. I'm still not 100% clear on what the issues you are see are? You say the rotations are not correct? What space are they being stored and applied in?
Paul Neale
http://paulneale.com
Paul Neale
Each bone has 3 matrices: TM, InverseTM, and LocalTM. My guess is they already calculated the Inverse Trans Matrix instead of doing the work by hand.
Each animation frame checks if there is a Bone Transform for each bone. If there isn't one, the it uses the Rotation quat and Translation stored therein.
My problem is that I do not know how to rotate and translate each bone. I don't know if its local space or parent space. I do know that a bone that has a parent bone is rotated in parent space but that really all I know.
I've tried a lot of things and this is pretty close but some bones are behaving wildly.
For BoneID = 1 To Animation.BoneData.names.Count Do (
if Animation.BoneTM == undefined Then
For FrameID = 1 To Animation.FrameCount Do (
Frame = Animation.BoneFrame
if Frame == undefined Then ( return 0 ) else
CurFrame = Frame
--curBoneFrame = Animation.BoneFrame
if (FrameID + 1) >= Animation.FrameCount Then ( nextBoneFrame = Animation.BoneFrame ) else ( nextBoneFrame = Animation.BoneFrame)
-- Get QuatSlerp
quatSlerp = slerp CurFrame.Rotation nextBoneFrame.Rotation Animation.PerSLERP
-- GetVecLerp
vecLerp = lerp CurFrame.Translation nextBoneFrame.Translation 1
-- Make new Rotation Matrix
mQ = quatSlerp as matrix3
-- Make new Translation
local mTemp = mQ
mTemp.row4 = vecLerp
format "Frame:% MatTemp:%\n" FrameID mTemp
if FrameID == Animation.FrameCount Then FrameID = Animation.FrameCount else FrameID += 1
if obj.parent != 0 Then (
with animate on (
at time FrameID
in coordsys parent obj.rotation = mQ;
in coordsys parent obj.pos = vecLerp
) else (
with animate on (
at time FrameID
in coordsys local obj.rotation.x_rotation = mQ;
in coordsys local obj.pos = vecLerp
