Align?
Align?
Align?
Hello i am trying to get a macroscript going that aligns a camera to an animated camera each frame and sets a keyframe. The alignment should be on xyz position as well as xyz orientation. I assume that if i have set animate on and sliderTime += 1 after i aligned it, the key frame is set automatically
In my head the code would look like this 🙂
set animate on - get timeline frames - select camera01 - align camera01 to camera 02 - sliderTime += 1 - repeat from select camera until current frame is equal to timeline end
Hope this helps. If someone could give me a hint or give me some code where i could start off would be great.
Cheers
Ralf
Assuming it's an animated camera with keyframes, the following should work. Change the camera names to whatever you need, etc.
startFrame = animationRange.start
endFrame = animationRange.end
set animate on
for f = startFrame to endFrame do
sliderTime = f
x = $Camera01.pos
y = $Camera01.rotation
$Camera02.pos = x
$Camera02.rotation = y
set animate off
Hope this helps.
