addNewKey not working
alecf
alecf
Hey there.
I created a "Key All" button in a UI that iterates through a bunch of controllers to set keys on position & rotation. addNewKey seems to be what I should use, but it just isn't working.
My rotation is a rotation_list, with three euler_xyz underneath it.
I want to key the third euler_xyz track on the current frame.
So, here's what I tried:
indirect method -
addNewKey $objectName.rotation.controller currentTime
explicit method -
addNewKey $objectName.rotation.controller.ThirdRot.controller currentTime
Neither works. What happens is that once I addNewKey and then rotate the control, the values of the existing keys become the values of the control's current position.
I've looked into "on animate" but that doesn't seem to be what I want.
Any hints on what could be causing this behavior?
Alec
alecf
nevermind. it seems Set Key has to be active for this to work.
Unfortunately, there doesn't seem to be a way to determine whether or not Set Key is active or not...there's just a way to toggle it with "max set key mode".
Answers one question and suggests another....
