Announcements
Adding multiple batch renders with area to render set to "Blowup"
bertv
bertv
I have a scene that needs to be rendered very big. I made a script to automate this using multiple blowup renders. The blowup region renders fine when submitting to the backburner server, but only when using one batch. When submitting multiple it only uses the last set blowup region.
Can I add batch renders to the batch each using their unique blowup region in the camera view?
This is the part for my code where I create the blowup regions and add them to the bath:
			--Set render type
			--#view | #selected | #region | #crop | #blowUp | #boxselected | #regionselected | #cropselected | #normal | #selection | #regionCrop
			setRenderType #blowUp
				if renderSceneDialog.isOpen() do renderSceneDialog.update()
			--Set blow region
			box_blowup = (Box2 posVector[1] posVector[2] FullRecWidth FullRecHeight)
			viewport.setblowuprect viewport.activeviewport box_blowup
			--Create camera batch for blow region data
			orthoCamBatch = batchRenderMgr.CreateView orthoCamObj
			orthoNameCam = counter as string + "_" + orthoCamObj.name
			orthoCamBatch.name = orthoNameCam
			orthoCamBatch.outputFilename = maxFilePath + orthoNameCam + ".png"
			orthoCamBatch.enabled = false
			--batchRenderMgr.netRender = true
			counter += 1
Any ideas how to do this?
Regards
Bert
bertv
I found out it's best to submit them directly to the render farm.
I used following docs to accomplish this by creating a job:
https://help.autodesk.com/view/MAXDEV/2022/ENU/?guid=GUID-DEF2CDBF-C729-46B9-BC0D-F030E255E3A7
regards,
Bert
