A Dll required for this install... error
I'm trying to download 2016 education version as a lecturer in university. I tried many times (autodesk virtual agent too) but it gave the error "There is a problem with this Windows Installer package. A Dll required for this install to complete could not be run. Contact your support personnel or package vendor" every time.
Here is my last installation log file:
2016/9/23:22:12:47 Burcu ASUSPC === Setup started on ASUSPC by Burcu ===
2016/9/23:22:12:47 Burcu ASUSPC Path_Length: 153
2016/9/23:22:12:47 Burcu ASUSPC Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm
2016/9/23:22:12:47 Burcu ASUSPC Launch
2016/9/23:22:12:47 Burcu ASUSPC CommandLine
2016/9/23:22:12:47 Burcu ASUSPC Current Directory C:\Users\Burcu\AppData\Local\Temp\_AID67A.tmp
2016/9/23:22:12:53 Burcu ASUSPC === Setup ended ===
2016/9/23:22:12:50 Burcu ASUSPC === Setup started on ASUSPC by Burcu ===
2016/9/23:22:12:50 Burcu ASUSPC Path_Length: 153
2016/9/23:22:12:50 Burcu ASUSPC Current Directory C:\Users\Burcu\AppData\Local\Temp\_AID67A.tmp
2016/9/23:22:12:50 Burcu ASUSPC Launch
2016/9/23:22:12:53 Burcu ASUSPC PageOpen LaunchDialog
2016/9/23:22:15:46 Burcu ASUSPC PageOpen LicenseDialog
2016/9/23:22:15:49 Burcu ASUSPC PageOpen ProductInfoDialog
2016/9/23:22:22:51 Burcu ASUSPC PageOpen ProductSelectionDialog2
2016/9/23:22:23:08 Burcu ASUSPC PageOpen FullProgressDialog
2016/9/23:22:23:08 Burcu ASUSPC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/9/23:22:23:15 Burcu ASUSPC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/23:22:23:15 Burcu ASUSPC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/9/23:22:23:20 Burcu ASUSPC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/9/23:22:23:20 Burcu ASUSPC Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/23:22:23:27 Burcu ASUSPC Install DirectX® Runtime Succeeded
2016/9/23:22:23:27 Burcu ASUSPC Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/23:22:24:06 Burcu ASUSPC Install Autodesk® Material Library 2016 Failed Installation aborted, Result=1603
2016/9/23:22:24:06 Burcu ASUSPC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/9/23:22:24:06 Burcu ASUSPC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/9/23:22:24:06 Burcu ASUSPC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/9/23:22:24:07 Burcu ASUSPC PageOpen InstallCompleteDialog
2016/9/23:22:24:09 Burcu ASUSPC === Setup ended ===
2016/9/23:22:27:52 Burcu ASUSPC === Setup started on ASUSPC by Burcu ===
2016/9/23:22:27:52 Burcu ASUSPC Path_Length: 153
2016/9/23:22:27:52 Burcu ASUSPC Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm
2016/9/23:22:27:52 Burcu ASUSPC Launch
2016/9/23:22:27:52 Burcu ASUSPC CommandLine
2016/9/23:22:27:52 Burcu ASUSPC Current Directory C:\Users\Burcu\AppData\Local\Temp\_AIA5AA.tmp
2016/9/23:22:27:57 Burcu ASUSPC === Setup ended ===
2016/9/23:22:27:54 Burcu ASUSPC === Setup started on ASUSPC by Burcu ===
2016/9/23:22:27:54 Burcu ASUSPC Path_Length: 153
2016/9/23:22:27:54 Burcu ASUSPC Current Directory C:\Users\Burcu\AppData\Local\Temp\_AIA5AA.tmp
2016/9/23:22:27:54 Burcu ASUSPC Launch
2016/9/23:22:27:56 Burcu ASUSPC PageOpen LaunchDialog
2016/9/23:22:30:37 Burcu ASUSPC PageOpen LicenseDialog
2016/9/23:22:30:39 Burcu ASUSPC PageOpen ProductInfoDialog
2016/9/23:22:31:39 Burcu ASUSPC PageOpen ProductSelectionDialog2
2016/9/23:22:31:41 Burcu ASUSPC PageOpen FullProgressDialog
2016/9/23:22:31:41 Burcu ASUSPC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
2016/9/23:22:31:46 Burcu ASUSPC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2016/9/23:22:31:46 Burcu ASUSPC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
2016/9/23:22:31:51 Burcu ASUSPC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2016/9/23:22:31:51 Burcu ASUSPC Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/23:22:31:59 Burcu ASUSPC Install DirectX® Runtime Succeeded
2016/9/23:22:31:59 Burcu ASUSPC Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2016" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/23:22:31:59 Burcu ASUSPC Install Autodesk® Material Library 2016 Failed Installation aborted, Result=1603
2016/9/23:22:31:59 Burcu ASUSPC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/9/23:22:31:59 Burcu ASUSPC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/9/23:22:31:59 Burcu ASUSPC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
Thanks in advance
Burcu
