3DS Max interoperability not working
I downloaded a 3DS Max 2021 a week ago on a trial basis. Today I downloaded Inventor, also on a trial basis.
When I try to import my Inventor model into Max I get an error message telling me it is either not installed or not installed properly. I Open the installer, and low and behold it is infact installed.
As its a trial, is it worth me removing 3DS Max and then reinstalling it? I've attached an image with the error message. I hope there is a solution, as interoperability with Inventor is going to be a key part of my workflow, and one of the main reasons i'm interested in these two products.
Thanks for your time.
Luke
istan
I you expect a professional anwer, I would rather ask such questions on the right board..
We talk here about C++ and Maxscript programming..
Hi, this issue is NOT solved yet, nor can find it in another board ??
Hi 🙂
Nope, the issue is still on going, and the post can be found here:
https://forums.autodesk.com/t5/3ds-max-forum/inventor-interoperability-doesn-t-work-on-my-trial/m-p/...
It didn't help that I changed the title slightly! My apologies for the confusion.
