Why is making holes on uneven surface so hard in 3ds Max?
mamunmia1991
mamunmia1991
There is a script we used to use "edge loop regularizer" which is not working in the Max 2025 version. It was so handy. The given options are so complex to use. Some other 3D software provides convenient options for making holes. I want to know if there is any one-click option to make a perfect circle on an uneven surface. If not, I suggest authority to make a single-click option for us. We select the polygon/loop/border/object, click on circle/triangle/hexagon from the option, and boom it will transform.
pawel_karbarz
ProBoolean? You can cut a any-shape-hole in uneven surface and do more things with this tool. Also there is a Loop Tool which can help you to make a circle from selected edges.
