Verts won't weld
This widget could not be displayed.
Verts won't weld
I'm following a video on youtube http://www.youtube.com/watch?v=uHNzPpXemR4
at approx 31.07 he closes up the door using the edge then welds the four into two verts, i can only weld one or the other but not both, any ideas???
When you click on the weld menu, just increase the threshold and that should do the trick
I tried that, still wont weld! I've no idea what's going on. Smiley Frustrated
Steve_Curley
Uncertain without having the scene to look at, but it's likely that you're trying to weld vertices which cannot be welded. Looks like you're trying to weld vertices which would result in the Edge between them having more than 2 Polys attached to that Edge, which is not possible.
If you want someone to look at the model and tell you for certain, zip the scene (the .max) and attach it to a reply.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
