Announcements
Vertices not aligning to a single vertex
I seem to be running into the problem when I max zoom to a point where I have aligned my vertices that they still display as separate points, but when I check their individual coordinates in the bottom right the numbers are exact. I am working with both my System/Display units in centimeters. This is the first time I've noticed this and it definitely throws me off while working... Thank you in advance
CAMedeck
Zooming in all the way will frequently show small eccentricities like this.  It comes down to small rounding errors in the software, but should not affect your rendering.  This gets worse as you get further from the origin, or even have objects far from the origin.
Chris Medeck
Makes sense, thank you for your explanation!
