12:08 PM
So I'm working on this door, I detached the bottom and top and continued working what I didn't notice is the I had selected some vertices on top of the door and detached them along with the bottom. I figured attaching everything and welding the vertices back together and then detaching again would fix it. Well, all but 3 vertices will not weld. I tried target welding and then getting the edges/vertices closer together. Still nothing happened. Please help. Also if you could explain what happened and it English, please. I would appreciate it. Thanks.
I've uploaded the file, the vertices are on the far outside right says vertices 124 when attempting to weld.
Link copied
