swift loop
swift loop
Nazzaman
Message 1 of 15
swift loop
Nazzaman
Very excited with 2018 version of 3dsmax. Just wondering what happen to 'swift loop' command?
Accepted solutions (3)
Replies (14)
Message 2 of 15
don_3259
hi what happen is it not working ?
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
Message 3 of 15
Nazzaman
I finally found it in custom user interface/ command. I noticed the command/icon no longer in modelling ribbon.
Message 4 of 15
Alfred.DeFlaminis
Hello @Nazzaman,
If the Max window isn't maximized or you are using a small screen like a laptop, it may condense the ribbon menu a bit.  The tool is still there it just needs to be clicked on and then it appears in a submenu.  I've got an image below to show this, please let me know if you have any questions.  Thanks!
Best Regards,
Message 5 of 15
Nazzaman
It can be found if I change workspace into default workspace and turn on the ribbon feature. Thanks
Message 6 of 15
Alfred.DeFlaminis
Ah yes, it is a ribbon feature.  That's a good point, thank you for your post.
Best Regards,
Message 7 of 15
gustaw9cki
Observer
Observer
Hey, I've got problem with this tool on 3ds 2018. When I want to use this in ctrl+alt mode so that it creates parallel loops, it does nothing. How can it be fixed? On 2017 I didn't have this problem.
Message 8 of 15
It works. How works with ctl+alt is that it copies the shape of the side you are dragging towards. If none of them is flat, the swift loop won't be either. But whatever shape it will be consistent as long you move in the same direction, allowing parallel loops, even if both sides are different.
Message 9 of 15
gustaw9cki
Observer
Observer
The thing is that when I try to move towards one of the sides, I cannot do it. The loop I've created is in the same place all the time and I can't add another or move. When I press CTRl+Alt nothing happens. The tool acts like frozen.
Message 10 of 15
The loop needs to be selected (red) . In fact it is irrelevant if the loop has been created with Swift loop. You will be able to move it as long is red and you are in swift mode with ctrt+alt
If you lose the selection of the loop simply re select using ctrl in Swift loop mode.
Message 11 of 15
gustaw9cki
Observer
Observer
Yeah, I know. It glows on red and still nothing. I know that it has to be selected previously and this is the thing. I can't move although I selected it.
Message 12 of 15
In that case I can't replicate working with a edit poly modifier or editable poly. . It must be a problem for you mesh or you max configuration.
Message 13 of 15
jme
Observer
Observer
I have exactly the same issue with swift loops....
Message 14 of 15
wizotchalunmai
Observer
Observer
its not even in the ribbon, i could not even find the "edit" in the ribbon
Message 15 of 15
dmitriy.shpilevoy
It is there in max 2021, 2023. Maybe your object is incompatible - try converting it to Editable Poly.
