Split an object into two parts
Message 1 of 8
Hi everyone !
I have trouble with a part of an airplane object from the simulator X-Plane 11.
The engines parts are coming together (two), and I'm having troubles with that.
The best would be spliting the engines, in order to have only one instead of two in the file.
Can someone do that for me please ? I don't have the software and the suffisant knowledge for that.
I attached a screenshot with what I have.
The file is an ".obj" file.
If someone can help me, I can send you the file by mp 🙂
Regards
Replies (7)
Message 2 of 8
don_3259
hi mangakunk please explain this clearly what you want i can help you...thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
Message 3 of 8
Hi Don !
Thanks for your reply !
To be simple, I would like to delete one engine in the file and have only one.
Regards
Message 4 of 8
don_3259
ok send me file i that for you ... share file here
Ali Sajjad
Message 5 of 8
Thank you for your help !
I sent you a mp ! 🙂
Message 6 of 8
don_3259
file is not opening in 3ds max saying empty file
Ali Sajjad
Message 7 of 8
Did you opened the two files ?
Whatever, no problems, thanks for trying to help me ! 🙂
Message 8 of 8
Hi Mangakunk,
 If you import .obj file in 3ds max it'll be in the form of Editable mesh.
You can detach the object by selecting it from element subobject.
Hope it'll be useful for you.
If not do send me the file. I'll try fixing it..
