i am working with 3ds max 2015 and my soft selection is not working i dont know why help me out here please
Hello @vinsleyayuba,
I'm happy to help you with your problem, but I'd need a bit more information to do so. Is it possible to post a simple scene file that has your issue or a screenshot of the problem, please? Depending on your scene scale you may have to adjust the falloff until it affects more vertices or faces.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
I tried increasing the offer but it's not affecting my object...I don't know why, I tried using the edit tool it wasn't working..... for a while then it started working...thank you ā,i will b sure to get back to u if I run into more hiccups.....
I understand completely.
If you continue to have trouble, I'll be there to help you with your technical problems.
Best Regards,
