Announcements
Rolling a mattress
Rolling a mattress
I've got a question regarding a short animation I want to make. A good example for this, a mattress I want to roll up. The "Bend" modifier doesn't seem to work as it will just make a circle and not fill the center. Does anyone have any idea's how I'm able to make this as an animation?
leeminardi
I experimented with changing the radii and number of turns of a helix (as a renderable rectangle) and got the following. Not a final solution but this approach may have potential.  I also considered using a PathDeform modifier applied to a box that references a spline that was converted from a helix but ran into some problems.  This is a work in progress.
lee.minardi
miledrizk
I made this screencast to demonstrate one way to do this using the Bend modifier
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Irshad_Shah_3dArtist
Hi Mate..
Check this video
https://www.youtube.com/watch?v=uAMul131Avc
Although it's not in good quality but you'll get what are you looking for.
Thank you
Irshad Shah
StephenMF
I would try a bone chain... use as many bones as needed...
Please show us end result.
Stephen
