Rendering a wireframe object
I am trying to render this model of a pendant light I got from 3D Warehouse.  All of the geometry is there, but the individual lines are not rendering.  I am not sure how this was built, so there may be a modifier that will make the geometry render correctly or convert it?.  Image of pendant light and zipped file of model attached.
When you say "the individual lines are not rendering", i understand that those lines are the sphere surrounding the light.
First, add light(s) to your scene and adjust your exposure control.
I have opened your file and disabled the exposure control and here what i got.
So , this is a simple render, with the default lights, no exposure but show that the problem is your light settings
Eric, Thanks for the reply,
Once it is rendered, the lines look too weak...I think we just need to add more density to the model by adding more geometry.  We also found a few good models on TurboSquid that may be easier than trying to adjust this model.  Thanks for taking a look..!
-Ralph
