Solved by kgokhangurbuz. Go to Solution.
Parts are combined by attaching them (you've done that) and then welding the vertices of the two parts to make them one.
Hello;
Yes, there's a way and it's a common way which is almost a standard workflow for such actions you'd like to apply on your model. This action is called Collapsing Geometry.
First of all, you should not attach such objects if it's a matter of transparency / opacity / refraction. Please follow these steps in your workflow:
Position two or more objects with intersecting volumes and select one of the geometries (again, none of them should be attached) Fig01
Go to Either Create > Geometry > Compound Objects > Proboolean (or Boolean, but Proboolean is preferred in most cases) or Utilities Tab in your Command Panel
For Proboolean / Boolean:
-Select the Union Option under Parameters > Operation Tab
-Click on Start Picking / Pick
-Click on the other geometries
-You can see that they share the same volume now, because the intersecting parts are removed from eachother and the geometries became one single object.
For Utilities Section Fig02:
-Choose all the geometries that intersect
-Click on Collapse
-Choose Single Object > Boolean > Union
-Click on Collapse Selected
Regards;
