Question about using cut on a polygon.
tranngochungdevwannabe
Community Visitor
Community Visitor
Community Visitor
Im new to 3dsmx and have some confuse with using cut on a polygon of an Element.
Step I did:
1. Creat rectangle.
2. Use modify edit poly.
3. Choose polygon -> choose cut.
4. When I click on the surface, it alway auto generate edge that connect from the point I click to the vertex on the border of that polygon (in the pics they are edge x). Why is that? Can I just cut it like cutting a cake? Why extra edge have to appear?
5. When I switch to edge and choose (u can see which edge I mean in the pics) a or b or c or combination of any  of them and click 'remove', it remove all a,b,c, x. How to remove only the edges I choosed?
    Also if I choose edge x, then click 'remove', nothing happen. Can I remove edge x? How?
6. If I choose polygon Z, then click button 'delete' on keyboard (since there is no 'remove' function that I can choose for polygon. Why edge have this function but poly dont have?), then click on l or m or n or combination of them, then click 'remove', nothing happen. This behave differrent with a,b,c , was edge a,b,c deleted with polygon Z?
    Still, now when I click edge x, and click 'remove', nothing happen. How can I remove this edge x? Why it have to appear in the first place?
7. Also, when u guys create new edge(s) for object using edit poly modify, did u use 'cut' or something else?
   I tried to use: in edge mode -> Edit Geometry: 'create', but it only can creat line from a pre-exist vertex to a pre-exist vertex.
   I try 'insert vertex' (still edge mode) but it can only create vertex on a pre-exist edge, also after that I use: in edge mode -> Edit Geometry: 'create', resuilt is only from some vertex that I can create edge, some cant.
   Also if I use vertex mode: -> Edit Geometry: 'create' to create vertex, then switch to edge mode to create edge, I cant click to those vertex at all.
Im clearly using this app wrong :)))
I use 3ds max 2021.
ahmadhossain50
Cut tool is sensitive tool. If there is no segment, it creates auto segment. If you draw triangle on a plane, for example you create a plane with 1 by 1 segment. Then, you draw triangle, you get automatic segment because the software is designed like that and without segment you cannot control the triangle in many cases. I just upload a photo. Actually, Segment controls the smoothness of a surface of a geometry and Segment also helps to an object to make real. If you look realistic model, Modeler controls segment properly. A Good modeler means who knows good segment control.  Cut tool also uses to control segment. If there is Segment, Cut tool will not create automatic segment. There are two photos.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
