Problem with UVW Unwrap
leonardo.k
leonardo.k
Hey guy!
Need a little help here... I'm new in 3DS Max, so maybe I'm doing something wrong here.
I model a simple cushion, very simple, and then I try to unwrap to apply some textures.
I saw this video: https://youtu.be/9JpLf0mi78k  and I think this is a very simple way to do, so, I try in my model, bu...
Thanks a lot for the help.
dmitriy.shpilevoy
I don't see anything wrong and not even sure what the problem is. I guess you want mirrored elements sewed together.
Go with what you have at 1:38.  Switch to faces subobject and deselect everything. Go to unwrap's menu.
select / select inverted polygons
if anything is selected - mirror/flip it
Use stitch on adjacent edges. Weld and target weld stubborn verts if any.
leonardo.k
Hey @dmitriy.shpilevoy thanks for the tip, but I found a easy way to fix that:
See, there is a another modifier "UVW Unwrap Clear" that complete wipe out all seams that 3ds create, and after that with UVW Unwrap 3ds will accept my lines as a seams.
I didn't note this modifier yesterday, for now on I will use this modifier always.
Thanks again for you tip!
