I'm having trouble using Axis Constraints to snap to stuff in Max 2019, and actually in previous versions going back to 2016 (abandoned previous attempts to use them and just used a more laborious workflow).
As far as I can see from the Autodesk documentation and any other resources I can find, it's a simple case of toggling the axis constraint/constraints you want to use on while ensuring that the Enable Axis Constraints in Snaps Toggle is also toggled on. I've done this and also checked my Grid and Snap settings to ensure the Use Axis Constraints checkbox is ticked which it is. When I select an object/vertex etc and move it with for example the X axis constraint selected, it can move on Z and Y as well, and if I deliberately grab the handle for Z or Y to test it, the Axis Constraint actually toggles to whatever axis I've tried to move, which seems bizarre as this is the precise opposite of the behaviour I would have expected. Any suggestions would be hugely appreciated.
