3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Placing Rivets on Complex Shape
2 REPLIES 2
Hallw8
377 Views, 2 Replies
I'm doing a project where I need to place a massive amount of rivets onto an aircraft fuselage. I'm doing the rivets by having a repeated plane uv'ed to a separate high res texture than the rest of the fuselage. I have tried a few different tools such as the object painter but am struggling to get uniform lines as there's no way that I know of to snap the brush to a straight line. There is a rivet plugin but that is using the number of rivets between two points rather than an interval between each object.  Is there another way to do this?
2 REPLIES 2
CiroCardoso3v
in reply to: Hallw8
Have you by any chance had a look at the OSL Rivets?
Could be something useful for you
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Hallw8
in reply to: CiroCardoso3v
Thanks for the response,
So that wouldn't work because they need to be placed correctly as they are in real life following lines on the texture underneath.
