Pivot Door Opens in a other way and width is not working
jimmygeorge
Message 1 of 10
jimmygeorge
I'm a newbie in 3ds max, while i trying to make a door for my walls, door is getting created but opens towards the wall instead of the free space. While i creating Depth is increasing instead of width.
Regards
Replies (9)
Message 2 of 10
jimmygeorge
When using the rotate tool, it gets corrected.
Message 3 of 10
irishman_team_kilber
when you create a AEC door do you use the snaps tool? in top view you drag out the widith then Depth then the height? once you selected the door you have tick/check boxes in the modify panel you can flip the swing you can make them double doors and flip the hinges the only reason that hignes are grayed out is because your in double doors,
Message 4 of 10
jimmygeorge
Yes, i'm doing like that. But i think my xyz co ordinates are changed, if i rotate that door to certian degree using rotate tool its ok, but i need to rotate every door which i create.
Message 5 of 10
jimmygeorge
Thanks for your reply. Actually i was doing wrong, first i clicked once there and then choosing another point, that was wrong. First choose the initial point then the second by dragging with pressing the mouse.
Message 6 of 10
as said if you use the snap tool to you create a windows/door then it should be ok, i am not sure why the XYZ is changing when you create the doors? when you in rotation use the Type in tranform
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
http://docs.autodesk.com/3DSMAX/16/ENU/3ds-Max-Help/index.html?url=files/GUID-B9779BBF-5B04-44EF-95E...
Message 7 of 10
leeminardi
Perhaps this screencast may be helpful to you.  Remember to use click-drag-click and not click, click, click.
lee.minardi
Message 8 of 10
isssyyy03
Community Visitor
Community Visitor
 hey!
how do I reduce the depth of the door?, I can only reduce the frame depth and not the actual door, may I know why?
thanks in advance
Message 9 of 10
leeminardi
@isssyyy03, Reduce the Leaf Parameters Thickness value.
lee.minardi
Message 10 of 10
isssyyy03
Community Visitor
Community Visitor
Thanks much!
