Pan/rotate viewports simultaneously
keith_brown
keith_brown
Hi!
Always when I'm modelling I use a reference object with turbo smooth applied to easier see what my low poly model will look like when smoothing is applied. Many times, however, when panning/rotating in the viewport I need to jump back and forth between the viewports holding the lowpoly model and the reference object.
Is there a way to simultaneously rotate two viewports globally?
I've tried to illustrate it below.
1) From Edit Poly view
2) It works a bit faster when exiting Edit Poly view and select the reference object. Still a bit time consuming when doing this often though.
So basically I want to speed up the workflow from within the Edit Poly menu... and best would have been if it was possible to simultaneous pan/rotate the viewports globally.
No, you can`t synchronize the viewports.
You can probably use 'Save Active Perspective View' and 'Restore Active Perspective View' and bind it to a Shortcut to speed things up.
Have you considered changing your workflow to toggling between subdivided/unsubdivided mesh by using a shortcut?
I attached a script that i found that you might find useful. You can bind this to a keyboard shortcut to turn on/off a Turbosmooth modifier on the stack of the mesh.So you can quickly preview the subdivided state of your model.
keith_brown
Late reply lol! This is awesome, thanks!
