3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
My objects are seeming grey
3 REPLIES 3
2396 Views, 3 Replies
Except a few, my objects are seeming grey and when I change their color, only their edges' color are updating correctly. Why the surface colors are not updating?
My model is in the attachments, thank you so much.
Tags (1)
3 REPLIES 3
miledrizk
Try saving it in Max 2018 so i can take a look at it
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
in reply to: miledrizk
saved in 2018. non of the ofbescts are frozen by the way.
miledrizk
The explanation is simple,
All your objects have Physical Material applied to them, except those in the image below
Objects with no materialsObjects with no materials
In the material editor, choose an empty material slot, then use the eyedropper near the material's name
And click on an object in the scene, other than those in the image above, and you'll see the object's material
Showing up. Now you can edit it as you like.
All have a gray color except the black metal on the table's legs which is also a physical material but
With a black color
Pick material from objects using the EyedropperPick material from objects using the Eyedropper
miledrizk@gmail.com
