Modelling water flow and splash/bubbles into a pool
vc-dw
vc-dw
Evening all!
Would be really interested to hear thoughts on modelling water flow and the splash of the water in to the pool as on the attached image.
I am thinking particle system for the flowing water, but not sure how to realistically get that to interact with the water in the pool?
Guess it would be better and easier to use  MaxFluids for this:
http://help.autodesk.com/view/3DSMAX/2019/ENU/?guid=GUID-423FC535-CBE4-46E0-A275-C36493D4A997
vc-dw
Awesome! Just having a look now, thank you 🙂
hagen.deloss
Hi @vc-dw
I wanted to check back and see if @Anonymous's post helped you with your problem? It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
vc-dw
Hi.
Update. I ended up poly modelling the water flow which gave a great result with a water material applied, quite simple in the end.
I looked at MaxFluids which looks amazing however I didn’t use it in the end for this. Little more practice required with this!
I used a particle system to add water bubbles to the top of the water. Then finished off in Photoshop to add a bit more of an effect.
Quick snapshot attached for reference
thanks for the input
hagen.deloss
@vc-dw
Thanks for the update, and this looks great! If you ever feel like sharing any of your work, feel free to post it to the 3DS Max Showcase thread, folks have been posting some really great work there!
Hagen Deloss
