mesh face normal problem
so I model this skateboard and I am seeing this black spot
miledrizk
Try to add an Edit Poly modifier and see if that fix it.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
thanks but it didn't work do you have any other ideas
miledrizk
If this is not a normal problem then it might be one of two things:
1- Simply because of the default lighting in the viewport: so I recommend you add a light and try
A test rendering to see how it will turn out.
2- Smoothing Group issue: I recommend you select all polygons and click Autosmooth in the
Polygon: Smoothing Groups rollout. You can start with the default value of 45, then you can
Experiment with different values.
Personally, I feel it's the first possibility.
miledrizk@gmail.com
hi
so did all things you say and everything is fine in the render but when i use max clay mode i see this
miledrizk
The light is so strong in your render/screenshot, no details left,
But regardless, what I wanted to say in my previous reply is that you don't really have a problem if
Your render is coming out right.
In the viewport, you have the default lighting, and if you orbit your scene and start viewing
Your model from different sides you'll notice that the shading will change, which is normal.
Below is a demo where I made a cylinder and applied a Noise modifier to it,
You'll see how the sading changes while orbiting.
The real criteria are when you render your model.
https://gyazo.com/2918ebea9cefc84d483cd1bf5868d064
miledrizk@gmail.com
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
