Mark area and create object
I have been searching and tryign alot to
mark an area (hole)  with special shapes so I can create a object to fill it.
But I can't find any tool that let me mark.
I have tested with spline lines. But I would avoid them.
Since they're just creating everything at wrong position etc and
not making it eaiser because of that.
Thanks!
With short words btw:
I wanna fill this area somehow:
https://www.bildtagg.se/file/vndk571g6j0847iumki3lhcc
Convert it to Editable Poly,, Select borders. Press CTRL + A  it will be selecting this area since it has Internal Edges Borders...  then go to Geometry , Creat a Shape from that Area, then Go to that shape convert it to Editable Poly,
Then you're partially DONE ! ,,,
after that you need to attach that New Poly Object to your main object,,, then Select All Vertices & Weld the Vertices to 0.01 mm so that new Polygon is 100% Attached to the object...  if you don't under stand  Watch this !
