how to use one object to cut into another object (complicated geometry)
Could you please help me with the steps to cut out part of a complicated geometry (image is attached) using another object?
leeminardi
Did you try using ProBoolean subtract?
lee.minardi
Hi, Thanks for your reply. I did try ProBoolean, but the geometry turned dodgy! Any chance for other solution?
Thanks a lot
And try Boolean ?
How did you create your model?
