How to quickly move multiple gizmo?
Pw232
Pw232
Hey guys, After I insert a group of plants. Their gizmos are always in the awkward position. And I only see centre to object option. I was thinking If I move the bottom of the group of model to 0 axis. Select all gizmos at once and then type 0 to the y axis then it would all be at the bottom. But can't seem to make it work. Could I get any advice please. Thank you.
10DSpace
@Pw232
The Transform Gizmo Icon appearance in your screenshot looks like you are in "Affect Pivot Only"  Mode.  Check the Hierarchy tab and switch "Affect Pivot only" to off by clicking on it (the shortcut toggle for this is the Insert key).  Then you should be able to transform all of the plant objects since now you will be transforming the objects themselves and not just their pivot.
domo.spaji
Z=0, not Y!
You can also press "Align to world" while there ...
