I don't think there is a good "automatic" solution for this one. Wicker is tricky to do. There are a few good tutorials online. But you may have to just get in there and create the mesh that represents it manually. You can do half and mirror it to save work, but I think this one might need to be done from scratch.
I guess you could try selecting all the edges of the front or back of that chair shell and detaching them. That way you'd have one surface of edges. Then put a 'Lattice' modifier on it and generate a wire mesh. You could then push and pull individual rows in or out to mimic the wicker. But it's going to be strange because the original spacing of all the rows and columns on the original chair mesh are different. Wicker is pretty evenly spaced all over due to the thickness of the reed used.
Someone might have a clever solution but I think this might have to be done the-old-fashioned-way.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
