How To Convert The Corners Of The Box Round.
I am facing a problem regarding making the edges of box round. if i use chamfer box it makes all the edges round. i just want the four corners to be round without affecting the rest of box. please help me if anyone can1.JPG
 This is the chair seating base  and its corners are round . if there is any way please tell me. Thanks!!
Accepted solutions (3)
Replies (7)
leeminardi
Convert the box to an editable mesh then select only the edges you want to apply the chamfer modifier to and then chamfer away!
lee.minardi
don_3259
hi dear friend can you please tell is that original shape without edges round yes you edit single vertex or edge chamfer in edit mesh or polygon method..thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
Thank you for the help!!! it really helped me I did chamfer but its pointy. As you can see in the picture . I want it to be a smooth curve as it was in my question first. I am just a beginner. do you have any idea how to do it ? It will be really helpful for my class project.111.JPG
Hi, i am a little bit confuse 🙂 since you mark the answers as solutions for your question.
So, i understand that you still need help to create round corner on your plane.
Here's 2 screencast that i made with 2 methods.
IMPORTANT, take a note that the 4 polys that i select at the end aren't quads, if you need to deform, animate or add a turbosmooth to this mesh, you will need to add extra edges for the corners.
Example #1
http://autode.sk/2mkIEgh
Example #2
http://autode.sk/2nmMA22
Thank you so much Eric. It Helped me very much.
don_3259
everyone here is to help dear acelivers just be happy always welcome
Ali Sajjad
