Hi there,
I'm looking to 3D print objects that have structural surfaces to improve wall strength that are inspired by plant cells - like the image below.
Any ideas about how to efficiently go about producing a mesh that I can export to STL without needing to be painstakingly build and/or repaired it?
I would ideally like to find a procedural process to save time and make variations. Looking at Script Spot i found the amazing http://www.automodeller.com/ So i can make flat geometry and then project it onto a curved surface for etc. but I'm still struggling to think of a decent way to build the cell walls as a single mesh object, or hundreds or thousands of individual meshes pushing up against each other like the image.
Thanks for any suggestions.
Anthony
