Help with edges
This widget could not be displayed.
Help with edges
Hi, I'm a beginner and I'm having an issue with an edge. So I'm following blueprints and I started by creating a plane and then Shift+drag to add more planes. Now I have to add an edge but it doesn't work and no idea how to do. As you can see below, I managed to create the edge on the horizontal part but I can't shift+drag anymore. How should I do? Is there any smart way to create 90 deg planes automatically without having to drag each line manually?
Thanks!
don_3259
hi babalaux try to delete faces and do one by one or share this file so we can do it for you .... thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
Try this one.
Edited by
Discussion_Admin
Hi Babalaux,
Try this step and do let me know it woked for you or not.
If not do send me the file I'll help you fix it..
Hi Babalaux,
iF it's Fixed,  do appreciate with Kudos.
Saguj
